Post your latest oil change
Saturday May 3 2025
2018 Toyota Tacoma TRD off-road
92380 miles
~9 months and 5 k on the oil
Previous oil change M1 0w50 FS. SP
Installed a Mobil 1 EP filter
This oil change I drained the pan with the oil pump and added
Mobil 1 0w40 FS SP
This is the 4-5 oil change with this oil and the SN version. I ran a couple of 10k changes with it but lately I have shortened them as my service is getting to be more special.
This past 9 months the the truck was used for several trips To and down PINS so lots of beach driving and some rough days where 4x4 had to be used to pull through. So some nice summer and fall days churning sand, also a lot of high speed highway tps to and from corpus and Houston with a few trailer pulls, past three months while I was out of town it had a lot of short trips as my wife preferred to use it most days. So in town errands etc.
I left the filter in with only 5k. Miles and having run this filter for 10k and it looking great when I pulled it I have no issues leaving it in since I am continuing with the same oil. Truck will see more of the same service this summer as last summer and fall, fishing 4 wheeling and some pulling.
Inspections I checked my ball joints and steering linkage found I have a minor play in steering linkage on Rfr so I plan to replace both sides.
Tires are a little tired the general grabbers held up well, but sun heat and time beats up every tire. Looking to replace this year.
Topped windshield was, brake and coolant levels and condition look good each less than 2 years old. May flush breaks soon do to heavy moisture on coast.
Review of The 4 uncles pump. Second use with it and I had to fiddle with it a lot to get a vacuum.. I don’t recommend it. Maybe there are better brands but it is unsatisfactory to me at this point.
Shouldn’t take so long to drain the oil started hot but was ambient by the time I was down. I rigged my shop vac too it and it was better than the hand pump..
The truck has had factory fill to 5 k
Castrol magenetec 5w30 to 10k
Dealer 0w20 to 15k
Castrol magenetec 5w30 to 20k
Dealer fill at 25k
I then went through a lot of 5w30 and 0w20 RTG every 5 k
I did a couple of 10 k intervals of Kirkland 5w30 before switching to mobile 1 0w40 in 2022.
Engine seems pristine, no oil consumption. No stains. Dipstick looks brand new.
No pics - I’m sorry. Toyota 5.7L
77k on the odo. 7300 on the oil.
OUT: 0W30 HPL premium plus passenger oil and amsoil Ea15k04 filter
IN: 0W30/5W30 50:50 HPL premium plus passenger oil and same amsoil filter
I used what I had. I’ll likely go 0W in the winter and 5W in the summer until my extended warranty is up. Then 5W all the way.
I'd be more concerned with sudden coolant loss. Unless Ford has addressed the issue, it isn't uncommon for the 1.5, 1.6 and 2.0 Ecoboost engines to have failed cylinder liners which result in coolant seeping into the cylinders. He's in the mileage range for this failure. That's an engine replacement.
The new Escape 1.5 is a totally different engine family.
I believe that is a completely different 1.5L that has the cylinder liner failures. The 2022 Escape would have the 1.5L 3 cylinder.
Correct.
May be, hopefully they've addressed the issue in their 3 cylinder engine.
They have.
I believe the redesigned 1.5L code named Dragon engine addressed those issues over the older escape engines which did have those issues. Time will tell if it has truly be resolved but so far so good.
Correct. It’s a good engine.
2021 Subaru Crosstrek 2.0 NA
45K miles on unit (44696 actual)/5k oci (5038 miles actual)
Out: 4.4 quarts Valvoline Restore & Protect 0W-20 and Purolator Tech TL14615 filter
In: 4.4 quarts Valvoline Restore & Protect 0W-20 and Carquest Red R84712 filter
Tire rotation as well. All work supervised and quality checked by my yellow lab, Floyd.
I’m glad Floyd was on the job site to make sure everything went smoothly.
‘23 Toyota Sienna Hybrid XLE
41,860 miles / 4,980 miles OCI
Out/In: Valvoline Restore & Protect 0W20 / 90915-YZZN1
2nd run of VRP. My son did most of the work while I supervised and supported.
Interesting thing happened with the black type OEM crush washer. The rubber or whatever it is coating on the washer came off and adhered to the drain pan and bolt. I was able to scrap it off fairly easily with a screwdriver. However this has never happened prior to using VRP. I have a supply of the blue coated OEM washers on hand so I used one of those on this OCI to see if it happens again. No noticeable leaks present. Let’s see if it’s an anomaly. More to come.
Was that a new washer when installed? Put a new one in some VRP and let it soak for a few weeks and see what it does to the coating.
The black coating on those Toyota drain plug washers don't last forever. Had them shed the coating after I've reused them for a few oil changes.
It was after only one use as I install new ones every time. I don’t have any more VRP on hand. But I might try the soaking exercise later.
I don't have any pictures of the truck.
I can tell you it's unrestored, and doesn't have a straight body panel on it. Cab corners and rocker panels are practically gone, frame is bent from a collision with a telephone pole twenty something years ago, and it has a big piece of sheet steel laid over the bed braces because the original steel was eaten away from hauling chicken manure for decades.
Its toasty but it still works
Subaru Forester 2024. 19947 total miles. Out: VRP 0w20 after 5100 miles. In: Mobil 1 ESP 0w30 with Subaru filter. Will change it every 5000 miles. It's been getting a bit better than 30 mpg on 20 weights until now. I'll bet it doesn't change a measurable amount. Love the way it sounds on start-up now...these aren't sewing-machine-smooth engines on start-up!
2019 RAM 1500 Sport - 5.7L HEMI
Engine mileage: 122,839km
Engine hours: 4,042 (614 idle)
Out: @High Performance Lubricants Super Car "Overkill" 0W-20, FRAM Titanium FS2
In: @High Performance Lubricants Super Car "Overkill" 0W-20, FRAM Titanium FS2
OCI length: 19,733km (12,261 miles)
OCI hours: 719
Oil added: none
This is my last FRAM Titanium kindly gifted by former member Rod Knock, so I've got two EaO's and then I'm into my stash of OG Ultra's, of which I have 9.
2005 Chevrolet Trailblazer (4.2)
75,616 miles
OCI: unknown
Out: M1EP, AcDelco PF61E
In: 5w30 M1EPHM, XG9837
I also flushed the factory fill brake fluid out. As you’d expect, it was really green. My pneumatic oil extractor with a brake bleeder hose made short work of it. It took almost three 12 oz bottles of dot 3 to get all 4 corners looking good.
OCI hours: 719
Oil added: none
That’s incredible to go that far and not have to add any oil! Those members here that call 0w20 “water thin” need to take note here 😃
