Post your latest oil change
2015 Chevrolet Malibu 2LT 2.5 LKW
51,128km
Purpose: Cleaned Intake Valves, hence the short oil change
Out: Motomaster OEPlus Import 5W30 & CarQuest 84502
In: Motomaster OEPlus Import 0W20 & CarQuest 84502
It was after only one use as I install new ones every time. I don’t have any more VRP on hand. But I might try the soaking exercise later.
You could just pull the dipstick a few times to get some oil off it to coat a new drain plug washer. Or if you still have the oil bottle, put it upside down in a funnel to drain out the remaining over a day and you'll get a decent amount out.
That’s incredible to go that far and not have to add any oil! Those members here that call 0w20 “water thin” need to take note here 😃
But what was the change in the oil level on the dipstick over the OCI. If it went down over the OCI, then it used oil regardless if no oil was added over the OCI.
But even if the oil level was one quart low that would still be impressive for this mileage. And I don’t think Overkill would let the oil level get that low
Not assuming anything about what Overkill did, just pointing out when someone says "didn't add any oil over the OCI" it could mean the level went from full to low on the dipstick. Yes, even if it did use 1 qt in 12K miles that's low oil consumption rate.
It was pretty much still at the full line, if that helps.
1998 Accord LX 4 banger, 188K, 4,725 OCI
Out: QS 5w30, TG7317
In: Kirk HM 5w30, Premium Guard PG4612EX
Oil was just below the add mark.
AC doesn't work, tried filling Freon stuff
Put 2 used tires on the rear for now. Needs alignment. Used rubber ain't so good a deal as it used to be... $130 for 2 off brand whatever.
Car was my folks, after they passed I gave it to a single Mom. She is now suffering from terminal cancer.
I will do more when I can get the car again.
We should all try to emulate this! Everyone of us needs help at one time or another. Good on Ya. I believe in karma.
Good for you JK. I know exactly what you mean about prices of EVERYTHING now. It seems to me for the past 12 months everything I see is double what it cost before. YIKES. We can not win. Retailers don't even seem to care anymore to even blame anything for increases. At one time they would blame it on everything under the sun and of course the prices of fuel. Nice of you to help out. (y)
2013 Silverado 1500 5.3L, 87,000 miles.
2,000 miles and 3 months on oil and filter. OLM at 66%. Early OCI following dealer replacement of leaking oil cooler lines.
Out: Mobil 1 0w-40 FS + Unknown quantity of dealer bulk, ACDelco PF48.
In: 5 quarts Mobil 1 0w-40 FS (SP) + 1 quart M1 0w-40 FS (SN), Carquest Premium 84502 (Vietnam).
2013 Silverado 1500 5.3L, 85,000 miles.
4,500 miles and 8 months on oil and filter. OLM at 11%. No oil consumed or added.
Out: Mobil 1 0w-40 FS (SP), Amsoil EaO17.
In: 5 quarts Mobil 1 0w-40 FS (SN) + 1 quart M1 0w-40 FS (SP), Carquest Premium 84502 (Vietnam).
2022 Ford Fiesta ST 1.5L 3-cylinder Dragon EcoBoost. 8500km on the vehicle, 2500km on the oil.
In/out: Valvoline Restore and Protect 5W-30 and Purflux LS1130 oil filter.
Attached a bunch of photos in case anyone was interested as these aren’t available in the ‘states. Cheers
View attachment 277237View attachment 277238View attachment 277239View attachment 277240View attachment 277241View attachment 277242View attachment 277243
I’ve always wanted to try a purflux filter here in the states.
I also have a Fiesta ST
Does the mk8 spec a fl910s from the factory? Because if it does I’m going to chase one of those purflux filters down
2008 Chevrolet Suburban
5.3 Vortec V8
Out: unknown oil, Fram Extra Guard PH10060 filter
In: Quaker State Advanced Durability 5w30, AcDelco PF48E filter
1990 Chevrolet Silverado 1500
5.7 TBI V8
Out: Castrol GTX 10w40, Schaeffer's Micron Moly EP, AcDelco PF1218 filter
In: Fram conventional 10w40, AcDelco PF1218 filter
The Mk8 specs the smaller filter, Ford part number H6BG6714BA.
The Purflux part number for the Mk7 is LS934.
