Saturday May 3 2025
2018 Toyota Tacoma TRD off-road
92380 miles
~9 months and 5 k on the oil
Previous oil change Mobil 1 0w50 FS. SP
Installed a Mobil 1 Extended Performance filter
This oil change I drained the pan with the oil pump and added
Mobil 1 0w40 FS SP
This is the 4-5 oil change with this oil and the SN version. I ran a couple of 10k changes with it but lately I have shortened them as my service is getting to be more special.
This past 9 months the the truck was used for several trips To and down PINS so lots of beach driving and some rough days where 4x4 had to be used to pull through. So some nice summer and fall days churning sand, also a lot of high speed highway tps to and from corpus and Houston with a few trailer pulls, past three months while I was out of town it had a lot of short trips as my wife preferred to use it most days. So in town errands etc.
I left the filter in with only 5k. Miles and having run this filter for 10k and it looking great when I pulled it I have no issues leaving it in since I am continuing with the same oil. Truck will see more of the same service this summer as last summer and fall, fishing 4 wheeling and some pulling.
Inspections I checked my ball joints and steering linkage found I have a minor play in steering linkage on Rfr so I plan to replace both sides.
Tires are a little tired the general grabbers held up well, but sun heat and time beats up every tire. Looking to replace this year.
Topped windshield was, brake and coolant levels and condition look good each less than 2 years old. May flush breaks soon do to heavy moisture on coast.
Review of The 4 uncles pump. Second use with it and I had to fiddle with it a lot to get a vacuum.. I don’t recommend it. Maybe there are better brands but it is unsatisfactory to me at this point.
Shouldn’t take so long to drain the oil started hot but was ambient by the time I was down. I rigged my shop vac too it and it was better than the hand pump..
The truck has had factory fill to 5 k
Castrol magenetec 5w30 to 10k
Dealer 0w20 to 15k
Castrol magenetec 5w30 to 20k
Dealer fill at 25k
I then went through a lot of 5w30 and 0w20 RTG every 5 k
I did a couple of 10 k intervals of Kirkland 5w30 before switching to Mobil 1 0w40 in 2022.
Engine seems pristine, no oil consumption. No stains. Dipstick looks brand new.
