Haha absolutely. These cars are so simple and reliable I couldn't help but add it to the fleet as a backup car.That was nice of your buddy to finish breaking it in for you.![]()
2013 Silverado 1500 5.3L, 75,500 miles.
4,800 miles and 8 months on oil and filter. OLM at 17%. No oil consumed or added.
Out: Mobil 1 Advanced Fuel Economy 0w30, Royal Purple 10-48.
In: Mobil 1 0w-40 FS (SP), Amsoil EaO17.
Why do you use 0W20 and 75w80 for transmission? I have heard from Problems with the second gear. I will try a thicker one like 75w90.2024 FL5 Civic Type R break in fluid change
Molygen 0w20 + Oem Honda filter
Ravenol 75w80 manual transmission change
View attachment 214071View attachment 214072
The car is specced 0w20 and even with spirited driving oil temps barely tap 200f. For track duty it gets motul 0w20. Swapping to ravenol 75w80 has completed removed any 2nd gear grind.Why do you use 0W20 and 75w80 for transmission? I have heard from Problems with the second gear. I will try a thicker one like 75w90.
2017 Toyota Sienna 3.5 V6
78,618 miles
On sale Napa syn 5w30, Fram CH9972
Replaced filthy cabin air filter with Microgard 3684
Replaced original engine air filter with Fram Ultra 10755
I assumed it was the original as it was a Toyota Denso, and my neighbor bought it used and never had it dealer serviced. Rather than chance it being the original I just swapped it out.I thought I was bad, having almost 60,000 miles on my Corvette’s original air filter. I wish it was an easy swap, but unfortunately a lot of stuff needs to come off to change it, which is why I have put it off for so longBut at the same time, I have found the roads I drive on are pretty easy on my air filters. When I looked at the one on my Honda after it was in there for 25,000 miles it still looked almost as clean as a new filter
new to me 2005 Honda Accord 2.4L with 154k on it. bought it as i’ve just accepted a new job offer that will have me commuting 70 miles per day.
unknown mileage in service.
out/off: unknown oil and STP S7317
in/on: 4 quarts Pennzoil Ultra Platium 5w30 and 1 quart HPL Engine Cleaner 30 with OG wire backed Fram Titanium FS7317.
i plan to run this combo for 5k then it will be put on HPL PCEO 5w30 for 12k OCI’s.
unfortunately my filter cutter won’t cut a 7317 sized filter.
