Post your latest oil change
Did my oil change today while it was slow
2020 Mirage 1.2 34k miles
Out: Pennzoil Platinum 0w20/ TG7317
In: Castrol Edge 0W20/ PH7317
2008 Honda CRV 2.4 VTEC 139K miles
Out: Unknown, Honda Filter
In: QS Full Synthetic 5W30 and Bosch 3323
Also changed serpentine belt and tensioner pulley, had to take the PS pump off and tensioner out since Honda thought it was cool to use a regular nut on the back side of the tensioner for threads and not capture the nut. I started threading the bolt back in with the new pulley and heard something hit the ground, it was the nut.... That was a pain. Also changed power steering fluid, brake fluid and rear diff fluid. Still have valve adjustment, sparkplugs, engine air filter, coolant and radiator hoses to do. Can't wait to be done with this one...
2013 Silverado 1500 5.3L, 80,500 miles. 5,000 miles and 8 months on oil and filter. OLM at 4%. No oil consumed or added.
Mobil 1 0w-40 FS (SP) and Amsoil EaO17 out and in.
2013 Silverado 1500 5.3L, 75,500 miles.
4,800 miles and 8 months on oil and filter. OLM at 17%. No oil consumed or added.
Out: Mobil 1 Advanced Fuel Economy 0w30, Royal Purple 10-48.
In: Mobil 1 0w-40 FS (SP), Amsoil EaO17.
Why do you use 0W20 and 75w80 for transmission? I have heard from Problems with the second gear. I will try a thicker one like 75w90.
The car is specced 0w20 and even with spirited driving oil temps barely tap 200f. For track duty it gets motul 0w20. Swapping to ravenol 75w80 has completed removed any 2nd gear grind.
1993 Toyota Tercel - 1.5L - 367131km on motor (187,131km since I rebuilt it in 2007)
5028km OCI - 2 years and 8 months
Out - Kirkland 5w30 and Fram Extra Guard
In - Supertech 5w40 Euro and Fram Extra Guard, plus aftermarket washer
This vehicle has been parked for a good portion of the OCI but is always ready to spring into action when needed. I'm selling a truck soon so will drive the Tercel until I get something else. It leaks quite a bit and also badly needs new valve stem seals. I probably put several litres in over the course of the OCI. I always wanted to get to 400,000km but someone else will probably have to take that on.
2017 Toyota Sienna 3.5 V6
78,618 miles
On sale Napa syn 5w30, Fram CH9972
Replaced filthy cabin air filter with Microgard 3684
Replaced original engine air filter with Fram Ultra 10755
I thought I was bad, having almost 60,000 miles on my Corvette’s original air filter. I wish it was an easy swap, but unfortunately a lot of stuff needs to come off to change it, which is why I have put it off for so long 😳 But at the same time, I have found the roads I drive on are pretty easy on my air filters. When I looked at the one on my Honda after it was in there for 25,000 miles it still looked almost as clean as a new filter
1965 Pontiac GTO
Fresh 389 Pontiac V8
Out: Comp Cams 10w30 Break In Oil, AcDelco PF24 filter
In: Swepco 306 Supreme Formula 15w40, AcDelco PF24 filter
2003 Chevrolet Silverado 2500 HD
6.6 Duramax V8
Out: Castrol GTX Diesel 15w40, Schaeffer's Micron Moly EP, AcDelco PF2232 filter
In: Swepco 306 Supreme Formula 15w40, AcDelco PF2232 filter
I assumed it was the original as it was a Toyota Denso, and my neighbor bought it used and never had it dealer serviced. Rather than chance it being the original I just swapped it out.
1999 Silverado 2500 LQ4. 132k on Odo. 13 months, 3100 mile OCI
Out: 6 qts Pennzoil Platinum 5W30, Ac Delco PF46E filter
In: 2 qts Castrol GTX 5W30 Synthetic Blend Superior GDI Turbo formula, 4 qts Valvoline 5W30 HM Synthetic blend, AC Delco PF46E filter
Out: 3~ qts ATF
In: 3~ qts Valvoline Maxlife ATF spill/fill.
Total Quartz made a potential 3-way salad cameo but didnt need it.
new to me 2005 Honda Accord 2.4L with 154k on it. bought it as i’ve just accepted a new job offer that will have me commuting 70 miles per day.
unknown mileage in service.
out/off: unknown oil and STP S7317
in/on: 4 quarts Pennzoil Ultra Platium 5w30 and 1 quart HPL Engine Cleaner 30 with OG wire backed Fram Titanium FS7317.
i plan to run this combo for 5k then it will be put on HPL PCEO 5w30 for 12k OCI’s.
unfortunately my filter cutter won’t cut a 7317 sized filter.
Sorry to break it to you but your Longacre cutter is adjustable so YES you can cut small filters. Done hundreds of small filters with mine. Ya need to move the bolts and rollers more toward handle. It’s so easy to do.
