post your latest differential fluid change
04 Chevy avalanche z71, 144xxx miles
Out: Delo 75w90 syn
In: ST 75w90 syn
Found it leaking and 2 bolts came loose, decided to just replace the factory cover w a new dorman cover, felpro gasket, and new SS bolts w a tiny bit of loctite
Out: Delo 75w90 syn
In: ST 75w90 syn
Found it leaking and 2 bolts came loose, decided to just replace the factory cover w a new dorman cover, felpro gasket, and new SS bolts w a tiny bit of loctite View attachment 40657View attachment 40658
Funny you mention that. On my avalanche, the fill bolt is rusted tight, so I used a similar cover to yours. Looks the same just not stainless.
I have had the bolts loosen twice now, despite a good tightening.
This spring I'm going to remove the cover and bolts and spray brake cleaner in the bolt holes out to remove the antiseize I used. I'm going to use a lube-locker gasket and locktite the bolts.
Another warm day in the south. Finally got the opportunity to drain the rear diff.
2018 Ford F-250 3:73 gears
Out: Mobil 1 30K miles
In: Redline 75W-140
2008 Nissan Titan 4x4, Rear Diff:
Out: Unknown, didn't look bad at all
In: Valvoline 75w140 + LG Gear Supp
T-CASE:
Out: unknown, dark
In: Castrol IMV
81,750 miles.
How many miles on the factory lube ?
17,100 mi
Bought it with 15,500 mi.
Not a Lucas fanboy. But RockAuto had it on sale for 4.99$ quart. Cant go wrong there.
Especially when good ole Datsun Nissan wants it changed every 20k/24 months. Who knows why but hey, they gave me 13k more than I originally paid for my previous 2018 Ram 1500 SLT so whatever.
Also: Nissan Dealer wants around 90$/qt for their Hypoid 75w90 GL5 Semi Synthetic Gear Oil part #KLD37-00001P which msrps for 139.95$/qt apparently
Thats not going to happen.
17,100 mi
Totally understand
Lucas for $5 bucks is a deal
Someday in the future when the price is right for ya
Pump in some Redline and ride for along long time
It’s good good stuff !
Any yes
Nissan price is stupid expensive !!!
Good luck sir
17,100 mi
I look at rock auto . Don’t see the sale .
In: Redline 75W-140
Any reason why you did not stick to the M1? How was it when you drained it?
Out: Redline 75w90 (12,000 km/two years) and the same fluid brand and weight went in.
I ordered it back on Jan 2nd. So IDK.
Work and stuff (Texas Snowpocalypse 2021) have kept me from doing it.
they were $5.20/qt - 5% code (-$0.26) so, $4.94/qt.
I dont post much here anymore, and usually when posting anything Lucas it becomes a Salem Witchhunt on here, so I never posted it in the rebate/sales forum. 🤷‍♂️
I did the Ford XR6 Turbo not long ago.
OUT: Penrite Pro Gear 80W-140 (Full Syn.)
IN: Amsoil Severe Gear 75W-140 from Amazon AU
Seems to like it, didn't need extra friction modifier either.
2019 Subaru Impreza 5 door w/CVT.
Drain n fill rear differential at 37k miles.
Out: FF
In: Subaru 75w90 gear oil.
