I put new pads and rotors on the rear of my dads 2016 3500HD Chevy. On these 11.5” AAM axles for the dually trucks, you have to pull the axles and hub assemblies to replace the rear rotors. It was a short OCI but it’s easy enough to change the rear diff fluid while I’m under there and doesn’t cost much, plus you lose some fluid when you pull the axles out. I used around $650 in parts (a friend let me have the brake parts at his cost) for a complete brake job and rear diff fluid change. The dealership will charge about $2,500 to do a brake job on one of these duallys. The rears call for about 2 hours per side to replace the pads and rotors. I went with Carquest semi-metallic pads and their platinum painted rotors. I got OEM seals and gaskets from my local Chevrolet dealer.
I priced OEM parts online and with shipping it was gonna be about $1000 for front and rear pads, rotors and the 2 seals and 2 gaskets.
OCI: 16,127 miles, 69,958 on the truck.
Out: 50/50 mix of syn 75w90 and 75w140.
In: almost 4 quarts of full syn 75w140.
