Do you mean a mix with more oil? More oil may actually a leaner mix, in regards to fuel, more oil , less fuel.A richer blend on the gas/ oil means longer life.
2xDo you mean a mix with more oil? More oil may actually a leaner mix, in regards to fuel, more oil , less fuel.
Having said that, i won't run my expensive chainsaw on anything other than 40:1.
Why not using proper 2 stroke oil?...well...here goes...I mix 1 part supertech tcw3 with 1 part walmart 30wt lubricating oil at 32/1. I use it in everything...tiller, ditch pump, wacker, blower, outboard, lawn tractor, chainsaw circa 1964 that runs great, Kohler K motor on my welder/gen, and pressure washer.
What exactly is proper 2 stroke oil...can't even get a consensus on what is a proper 4 stroke oil. If one visits screamandfly boat site many mix in aviation piston motor oil with their favorite 2 stroke oil. I'm not too good at following the corporate line..or company line of bs. I'll listen to old men...or ladies who have been there, done that first..Why not using proper 2 stroke oil?
You used half actual two stroke oil in your custom mix but the other half was 30wt for 4 strokes. Why not just use all two stroke oil and skip the 30wt?What exactly is proper 2 stroke oil...can't even get a consensus on what is a proper 4 stroke oil. If one visits screamandfly boat site many mix in aviation piston motor oil with their favorite 2 stroke oil. I'm not too good at following the corporate line..or company line of bs. I'll listen to old men...or ladies who have been there, done that first..
No No! The lubricating oil from WM is not motor oil. It is brightstock for pass-through applications.You used half actual two stroke oil in your custom mix but the other half was 30wt for 4 strokes. Why not just use all two stroke oil and skip the 30wt?
Proper 2 stroke oil is API TC, TCW3 or JASO FB, FC, FD.What exactly is proper 2 stroke oil...can't even get a consensus on what is a proper 4 stroke oil. If one visits screamandfly boat site many mix in aviation piston motor oil with their favorite 2 stroke oil. I'm not too good at following the corporate line..or company line of bs. I'll listen to old men...or ladies who have been there, done that first..
I am no less confused as to why you wouldn’t just use all 2 stroke oil that is meant for the task but if it works for you who am I to judge.No No! The lubricating oil from WM is not motor oil. It is brightstock for pass-through applications.
Aviation piston engines usually don't use motor oil like what we discuss here..
Do you see more or less smoke from one equipment to another, showing that gas tuning does impact smoke production over oil ratio?Just mixed another 2 gallons of 90 octane ethanol free gas with Echo Red Armor at 40:1. Run this in both of my Lawn-Boys, Husqvarna trimmer, Hitachi leaf blower, and Echo chainsaw.
L8R,
Matt
