Porsche 996 oil
I ran Redline 10w40 in my 964 cup and did indeed notice lower oil temps. I race a 996 cup now and have run Mobil 1 0w40, Millers 5w40 and Redline 5w40…ran the same oil temps with each….used oil analysis were similar but I do not have a long series of them to do a detailed comparison so they are just for amusement at this stage. Will probably run Mobil 1 0w40 this season as it is easily available and a darn good oil by most measures. I would think it would suit your M96 engine very well indeed.
Liqui-moly makes fantastic products.
I used their 0w-40 in my charger this past fall. Car always ran 213f oil temps at 70mph cruise enabled. I changed the oil to the liqui-moly and oil temps dropped to 190f.
Pretty significant change considering oil temps are supposed to increase with the use of thicker oil.
Redline is my favorite brand of oil without question. Liqui-moly comes in a very close second. And their additives are the only ones I will use. They perform as advertised,no snake oil with any of them.
They aren't well known this side of the pond however I am told that they are highly regarded in Europe.
Great products for sure.
As mentioned Mobil 1 0w-40 is also a world class product and has proven itself in countless performance vehicles over millions of miles. If you are in America it can be had for 25 bucks a jug which in my mind has no equal when one considers cost and value per dollar spent.
996, 986 Boxter: Pretty much well-sorted sports cars, but with the fatal IMS (intermediate shaft) flaw. The angular contact ball bearing that locates the intermediate shaft between the cam driven sprocket and the camshaft can wear significantly, bind, and break, causing the crankshaft and camshaft to come out of sync in a valve bender/ piston smasher/ conrod flailer event (on that cyl bank). IMO it's poorly thought out design detail in an otherwise clever and refined engine, and sadly, there is no reliable alternative than replacing those bearings to reset the self-destruct clock.
A friend of mine with an '01 Boxter has made a point to me that he will never buy another Porsche due to the way they (one of the most respected dealerships on the East Coast) passed off this fault as "a normal, typical high performance engine design, where catastrophic failures come with the territory, even at fairly low mileage." If you read the Rennsport forums you will see several years worth of disappointed owners ready to unload their Boxters & 996's, and Porsche North America now offering an out-of-court settlement to the class action lawsuit that pro-rates out of pocket rebuild repair expenses based on the age & mileage of the already affected cars (but accepts no responsibility for the poor design being the source of the problem).
If I were you 855R, I would ask the previous owner for service records on the intermediate shafts, or have them checked out ASAP. At least there is a warning for those who pay attention: most of those which are borderline make noise from the bearings for some time before they break.
And what oil to use? The one which lubricates caged ball bearings the best! But anecdotal evidence seems to show no correlation between type of oil or filter used, OCI frequency, driving habits, and IMS failure. Sorry to rain on your parade, this tempest has been brewing for 5+ years now - you should have done your homework, because even Porsche can make lemons.
Hi,
CentAmDL650 - With all due respect what did your post contribute to the OP's request for info? It simply denigrated his recent decision to purchase his Porsche
IMO such a post is unhelpful and not in any way productive!
Doug,
Realistically, this is probably the most relevant information any owner of a 986 or 996 could get. I wanted to impress on this fellow that the weak link in his new acquisition is in no way the motor oil, no matter which one he fills the crankcase with. He needs to research IMS failure with all haste, so he understands what he must do to protect his investment. There are some good videos on YouTube and on RennSport explaining it. In this case the motor oil selection is relatively trivial by comparison.
Porsche blew it with the weak IMS link. I think you can agree with that.
And surely there will be some silent 986 / 996 owners out there who will be disgusted that this information is being publicised, as it may make potential buyers more wary, their "issue" cars harder to sell. So be it. I recommend going in with eyes wide open, research completed. The truth is all auto manufacturers can and have made problematic models. It's never too late to step away from the Koolaid, and separate hype from reality.
guys, thanks for all your input. I was writing in interest as to what others suggested or what they run in their Porsches. I am fully aware of the IMS issues and have performed this procedure on a few. I know that regardless of the oil that I run it will not prevent this failure. Thanks again, for now I have a moly fill, the car has not smoked on start up for the past month or so but I may choose a different oil in the future, just because.
