Oil update: Went 2200 miles on the Delo 5w-40 XLE Syn. Changed oil and filter to Mobil Delvac-1 5w-40 ESP (CJ-4), Fram Ultra XG3675.
Oil pressure observations made above about Delo also apply to the Delvac. However, smoother still. My first use of Delvac 5w-40 ESP CJ-4, but I see why it costs more than TDT, RT6, and Delo. It seems to come up to temp faster (as judged by the OP gauge settling to normal ranges at idle and at 3k rpm in 4th gear) than Delo 5w-40. Already have 230-ish miles on the Delvac.
There was an ever-so-slight increase in the amount of ferrous sludge on the magnetic LNE drain plug in Delo over 15w-50, but I drove the car harder during the Delo run than with the M1 15w-50 (which was mostly highway cruising and some stop-and-go traffic). So, it's not a scientific comparison.
On all three heavier oils, I'm hearing and feeling noticeably less "buzz" at higher RPMs than on the 0w-40 oils. Though, to Castrol's credit, I did not have the low temp thermostat installed when I did my run of 0w-40 Castrol Edge black bottle. Nearly 25 degrees F lower coolant and oil temps when in traffic and hauling-the-mail would have had an obvious effect on KV.
IMHO, there is no reason to use the factory OEM filter when a Fram Ultra, Amsoil EaO, WIX XP, Napa Platinum, or Royal Purple option exists.
