Gokhan
This is great! I hope they are giving you a good price!I located some of the “Valvoline Premium Blue Restore” which only comes in 10w30 at a near by Cummins Sales and Service.
Question; if I’m burning on average about 1 quart every 1,500 miles and it’s probably best to run this stuff for 10,000miles(I’ll probably run it for 5,000miles). What do I do as the oil level on the VPBR starts to drop? Do I just top it off with any regular synthetic oil such as Mobil 1 FS 0W40 that you recommended?
also what is this Valvoline rebate I often see people talking about. Is it available only certain time of the year? Could I apply any kind of rebate to this expensive VPBR to help make it more affordable?
I am guessing your oil-fill capacity is more than 4 quarts. Therefore, you will need two 1-gallon bottles, as they are not 5-quart but 1-gallon bottles. If any oil is left after a 10,000-mile OCI, you can later use the remaining oil in the future for engine cleaning by mixing it with regular engine oil.
Note that this is a 10W-30 HDEO, which is thicker than a 10W-30 PCMO. HTHS is at least 3.5 cP for a 10W-30 HDEO (as opposed to about 3.0 cP for a typical 10W-30 PCMO) and KV100 is typically higher as well.
You will also need an excellent full-synthetic oversized oil filter—in other words the Fram Ultra XG3600:
https://www.walmart.com/ip/FRAM-Ult...-20K-mile-Change-Interval-Oil-Filter/16878921
https://www.amazon.com/XG3600-Ultra-Synthetic-Spin-Filter/dp/B000C2ZKJM/
It is very important not to use a regular oil filter with this oil, as you need both high efficiency and high capacity to filter out and collect the tremendous amount of carbon that will come loose.
I am pretty sure that the XG3600 will fit in, but you may want to verify the height and width clearances around the oil filter. In the unlikely event that it doesn't, you can downsize to the XG3614.
Good luck!
