Originally Posted By: Hub
I drive a 2000 F150 in SC as I would a Ford Edge, i.e. no loads, no hot rodding,no offroading, etc. Given this driving style, is it a big deal for the engine to be 1 quart low on oil? Will be changing oil/filter in approximately 500 miles so why waste oil if there is no benefit.
Would you fill it up with one less quart?
After all if it is no big deal why spend the money on the extra quart period?
Some questions...
How many miles on the oci?
When does it start to consume oil?
Sometimes the engine won't start to burn the oil until later as the oil gets sheered by contamination from blowby past bad piston rings. (I know oil is consumed all the time)
As the oil gets thinner due to this contamination it escapes past the rings more easily. If this is the case, i would change the oil as soon as the consumption becomes noticeable.
