Oil in buckets or in bottles?
Frisco, TX
I need to order my next batch of oil but have two choices this time: buy a case of the metal tins (2L each, 12 in the case) or buy a single bucket/pail that's 25L.
Buying the case makes it $13.88/L, but buying it in the bucket makes it $12.88/L after all shipping & taxes.
My only concern is that the bucket will be a major pain to deal with since I'll have no easy way to measure fluid out and pour it into the opening, short of getting a cheap pump. Is the bucket just too much of a problem to save a buck per liter?
Thoughts?
(if it matters, my car needs 10L per change, hence the desire to order a bunch at once)
The price difference is zero for my brand of oil 6 gallons @ approx 20 bucks each or a five gallon bucket for 100 bucks .
I buy the gallon jugs easier to store and deal with
Solution:
Buy pail
Buy cheap translucent plastic gallon pitcher from Dollar General or other mass outlet of plastic stuff.
Decanter the oil from the pail into the co-product of massive petroleum consumption resulting in the cheap availability of polymers to make anything in plastic.
Use.
Roust up a 5 quart jug with wide mouth... super tech, mobil 1, etc. Decant into this, then into car.
My work has a 5 gal pail of 10W diesel oil for our snowthrower (boss went a little overboard), and the "keg tap" pump and assorted hose is a sawdust magnet.
I see the bucket as being manageable, but my issue is how fast will you use it. A bucket has a large interfacial area touching air. I wouldn't want that for too long if I could avoid it, or I'd at least want to dose a bit of LC in there...
My car needs 10L per change. Based on my driving habits (7500/yr), I'll probably work through the oil in 18-24 months. Too long?
I've also read that the jugs actually have the oil inside a large plastic bladder.
That's correct - at least it applies to my bucket of Delvac 1300. I don't think that's too long of a period, in any case. As others have pointed out, just get a graduated pouring jug. I went to a local parts store and for a couple bucks I got a translucent jug with a nice spout marked in litres and quarts, and I can pour from the pail into the jug with minimal mess.
I recently used a 5gal pail of Rotella-T for a series of OCs on different cars. I had gallon jugs around (some from oil, some from things like washer fluid which I washed out). As mentioned, I decanted from the 5gal pail into 1gal jugs to be poured into the engine. I can approximate the 7L I need per OC and check on the dipstick when I get close so I don't need graduated pour containers.
It doesn't look like Rotella has a bladder, but it does have a pull out spout and a vent in the lid.
I'd by the larger pail. Put it on a workbench and tip it over into a 5qt oil jug. Use a funnel maybe.
Reuse the pail as a used-oil container to take to the recycle place. I have two, one always has some room for more oil. That's a good thing since I change oil on seven of my own vehicles and whoever else drops by for tools and oil.
