- Joined
- Jul 15, 2023
- Messages
- 1,702
Even the US manual says this:
The report won't really show much, but how is the gas mileage and the performance? Is gas milage = or > EPA ratings?I've got a 2022 Rav4 and its seen mostly 0w20 its entire life, reports always come back good. its usually changed around 7K in the summer and 5K (or less) in the winter/colder months. Just FYI.
Same. I think a high quality boutique 0w30 is about as close to a do-it-all solution as you can get. The higher VI index doesn’t bother me with something like HPL or Amsoil.You do know certain 0W-16's are VERY capable. Amsoil 0W-16 won't splode your engine.
https://www.amsoil.com/p/amsoil-oe-0w-16-100-synthetic-motor-oil-oes/?zo=515729
https://www.amsoil.com/p/amsoil-0w-16-100-synthetic-hybrid-motor-oil-he016/?zo=515729
https://www.amsoil.com/p/amsoil-signature-series-0w-16-100-synthetic-motor-oil-azs/?zo=515729
Nor will 0W-20
But I cut my own rug, I run 0w30 in all our vehicles!
That is stretching it unless.... you are using Amsoil and Amsoil oil filters.They change it every 10,000 miles. To my thinking that is stretching it
It's best to use what Toyota says to use...He show me on oil cap and it does say 0-16 weight
Gas Mileage is typically in the 35 MPG range, not a Hybrid. Performance is fine, its not a performance car but for daily driving its a great car. Only thing that I've done to the car is disable the Start-Stop system which drives me batty but that's personal preference.The report won't really show much, but how is the gas mileage and the performance? Is gas milage = or > EPA ratings?
I would imagine it would be O.K given the progression from 16 to 20 grade isn't much of a leap.
Now trying a 5W30 ACEA A3/B4 MB229.5, VAG 505 might be more of a "drag" than really needed.
thanks, cheetah
Arco,do you own toyotas vehicles that you run that oil in?This whole thing re: 0w8 or 0w16 has been hashed over for months in various threads that pop up every day it seems.
Same thing happened when 20 grade became de rigueur and a bunch of folks said, "I am sticking with 5W30!" lol.
-Arco
What I've been doing for years is changing the oil every 8000 miles, but I change the filter at 4000 miles and top it off.
See my signature line below post#22 (note: signature lines now appear only on the first post of a thread)Arco,do you own toyotas vehicles that you run that oil in?
