I am looking for an oil to run in a 440 mopar with flat tappet hydraulic cam with somewhat stiff single valve springs.
Based on limited understanding of all that would make an oil a good choice for this kind of motor, I have found two commonly available, affordable oils and would like to get your input on them. I think I understand that zinc and phosphorous should be high, but I do not know the effects of the difference in calcium, magnesium, boron and moly between these two oils. In a gas engine with no smog concerns or cat converters, would the difference in these make the NAPA oil, even with it's higher zinc and phosphorous, not as good (in terms of wear protection of cam lobes) as Delo 400 le?
These numbers are pulled from the TDR article:
Thanks for any input!
Dave
Dave
