On the recent GM 2.0L Turbo 4 and 2.5L 4 engines, the spun bearings that occasionally popped up, was it that the bearing clearance was too high, too low, out-of-round, flat spot, surface roughness, metallurgy or heat-treating? Does anybody know? Big-end bearings. Oil film "disrupted", meaning protrusion or too much clearance, or too little???
"The failures, according to GM, are caused by bad connecting-rod bearings that slipped past quality control at an unidentified supplier in June 2013. The flawed bearings can disrupt the oil film between the bearing and the crankshaft, leading to catastrophic metal-on-metal contact. “All engines now are designed to microns [0.00004 inch],” said Pawlik. “If the oil film isn’t consistent, bad things can happen.” -- from Car and Driver Article link
