Originally Posted by StevieC
In Amsoil's case for their Signature Series, they don't use a lot of VII's or any at all depending on the multi-weight formulation and rely on quality base oils instead for the properties they are looking for. I confirmed this by AMSOIL's technical line in an e-mail. They will confirm it for anyone that asks. Although it is further confirmed on the extended drain intervals we see where the oil's properties hasn't changed much from original.
"Don't use a lot"...not very scientific, and I'm sure that they are willing to tell anyone who calls similar. That's even less technical than the error riddle "paper" that started the thread.
OK, Amsoil ACD...which to be sold as a 30 NEEDS to be VII free...Oh, there's that pesky 4 ball in the data sheet too (and it's not even two years old...you know how I keep saying that the actual engine tests are a RECENT thing)...anyway, VI 146, which is exceptional for a monograde...I LOVE this oil. Just can't get it without getting raped in Oz.
https://www.amsoil.com/lit/databulletins/g27.pdf
Here's virgin spectrasyn 10
http://exxonmobilchemical.ides.com/en-US/ds244607/SpectraSynâ„¢%2010.aspx?I=30156&U=1
VI of 137, which makes me wonder about the "mono" in ACD.
So anything more than these two is affected by VIIs.
Signature Series
https://www.amsoil.com/lit/databulletins/g2880.pdf
ASM 0W20 - VI 169, so clearly contains VII, and a reasonable amount - Harman Index 0.903
ASL 5W30 - VI 162, again, clearly influenced by VII - Harman Index 0.931
AZF 0W40 - VI 184, again, clearly influenced heavily by VII - Harman Index 0.797
Let's see how they go against the "neutered" M1 EP range.
M1 0W20 - VI 173, so clearly contains an reasonable amount of VII - Harman Index 0.926 (clearly less effect of VII than the ASM)
M1 5W30 - VI 169, clearly influenced by VII - Harman Index 0.883
M1 0W40 ESP - VI 191 (calculated off Widman) - Harman Index 0.836
So as you can see, Amsoil's claim of "not a lot", when compared to the API licenced offerings indicates that their most closest competitor is also using "not a lot" also.
They were NEVER going to tell you that with all their "quality ingredients" that they used "about the same amount of their competitors".
You need to stop taking every bit of marketing as gospel fact....
edit...ooops Gokhan beat me to it.
