Originally Posted By: yvon_la
At op:nope!not directly at least!but it does act as a carrier (albeit unwillingly.the issue might be ethanol.why might?because I had gasket issue and yes it was caused the bio part in diesel fuel.at 2% biodiesel you won't have gasket issue because of bio.I would assume same thing that affected my truck probably also affect ethanol gas.since I haven't real data for car I extended my truck finding to cars.but oil isn't the issue directly itself.idea amount of bio and/or ethanol?1% is best!why not 0%?lubricity issue(ulsd or unleaded etc cause lubricity issue)
No, of all the things that Ethanol is demonized for... it won't make your gaskets leak in normal use. It doesn't even directly touch any oil wetted ones and should be able to be handled normally with pcv consumtion of vapors in any normal, modern system.
Originally Posted By: bigt61
Shockingly, some parts don't last forever. How old is this low mileage Camry? Does is sit out all day in the sun, or nestle in a cozy garage? How's the climate in your "world"? Believe it or not, all these things, and many others, affect component durability....not just your choice of oil & OCI.
These types of things make ALOT MORE OF A DIFFERENCE !!
BurrWinder
