Seems like this is a solution looking for a problem.It should heat up faster because there is a smaller mass of oil to be brought up to a certain temperature; by some fast calculations it takes 100+ watts of energy to bring 1L/qt. of oil from ambient to operating temperature.
Will it overheat? The oil cooling capacity should be the same because, the same amount of oil will flow and get in contact with the engine, there is just a smaller puddle in the oil pan. Thermal inertia is definitely lower.
OCI will have to be shorter, but it would also be cheaper.
This seems like a really good idea for a short-triper. Am I missing something?
In my case; my old Honda had a min-max of 2.5-3.5 and i've always just bought and poured in 3 bottles of whatever was on sale @ 6 month OCI (2-6k miles). The engine is tip-top, but the car is totaled . Now, my new Toyota has a min-max of 2.7-4.2 sooo I could do 3 bottles (which feels low) or I could do 4 bottles at ?... 6 month...1year... 6k miles... 10k miles... I don't know.
That is absolutely true - I run exactly midway between low and full on my ultra classic (96ci) because anymore and my leg gets oil on it! No my Softail Deuce (88ci) I can run at the full mark and no issues due to the different oiling system.in some vehicles with weak or inadequate PVCs, it’s a good idea to keep your oil fill between the full and low mark. Not the low mark. I fill my Harley 103 engine about a half qt low and get less oil in the throttle intake.
I'm one of those old timers. I consider the top (full) and bottom (add) marks on the dipstick the recommended range.For us old timer gas jockeys, we checked a lot of oil at those full service pumps, you never added oil until a car was a quart low, if only because it was adding a quart of oil or nothing.
Now in general, modern cars don't use nearly as much oil. Oil and transmission fluid are, again in general, the only two systems that have a low and full line. It's perfectly safe anywhere on or in between the two. I think this is a great discussion and falls between the two faithful BITOG responses.
The engineers know what they are doing.
It's cheap insurance.
That's a good point. I've owned some Japanese vehicles with a 3L (give or take) sump. Being a quart low would be just under 1/3rd of the oil volume missing.On a 60's VW, if you ran a quart low you'd be at 1.5 quarts total. Ouch.
I didn't think they had a very deep sump from the pictures I've viewed. I just didn't know how much margin there was for a bit of overfill. Apparently, not much.Yes sump is 2.5 quarts. Don't think I've ever over-filled but I do know the crank will hit the oil and aerate.
The oil bath air cleaner was just under half a quart so the last bits would get poured into the engine.
Will it overheat?
The engine is tip-top, but the car is totaled.
I don't know.
