For the past few months I've been using Mobil1 0W-40 with good results - good power, good gas mileage, and easy cold starts. For whatever reason, this oil change I decided to try that new Mobil1 SUV & Truck 5W-40 oil. My car has a gas powered engine but it calls for 5W-40 viscosity.
I changed the oil and drove the car after that. The morning after the oil change I had to crank the engine for 4 seconds before it finally started. Now the cranking went down to 2-3 seconds. When engine is cold it's very rough. Gas mileage went down to the point where I can actually notice the difference without writing down any numbers. The engine is much more quiet now but it takes some 20% more open throttle to get the same acceleration
With 0W-40 the engine took relatively long time to warm up. With this 5W-40 engine warms up some 40% faster - I guess the heat transfer/flow rate of this oil is not so high. Bottom line, I'm going to dump this oil as soon as it starts to get dark and I will go back to 0W-40 ![[Frown]](images/icons/frown.gif)
![[Confused]](images/icons/confused.gif)
