Originally Posted By: ekpolk
Originally Posted By: BuickGN
First off, the rod and main bearings are never dry started. I've torn down engines that have sat for years and there's still oil in the bearings.
For Pete's sake, I didn't mean
bone dry. As you very well know, bearings are not lubricated by the mere presence of residual oil -- they're lubed by pressurized oil that in essence forces the metallic surfaces apart from one another. If there's a tad of old residual oil in the bearing, and pressure takes a few moments to be established, the only protection the bearing will have in those moments before full pressure is established, will be from the add pack in the residual oil.
The only thing I would worry about is the time to the rpm in which it can devolop the hydrodynamic wedge which is viscosity independent. If anything I would think this would be quicker with a slightly thicker coating of oil on the bearings.
I have to respectfully disagree. The "wedge" is not going to form until full (or close to full) oil pressure is established, with the full necessary volume of oil in the bearing space. A small amount of residual oil is better than nothing, but it's no substitute for fresh oil flowing at the appropriate volume and pressure.
I was giving you a big "if" when I said miliseconds. We don't know for sure that it takes any longer for a 30wt to reach parts. If the ADBV is working you have oil movement from the first degree of crank rotation.
Two thoughts here. First, right, we don't know. One thing we DO KNOW FOR SURE, is that the 20 wt oils have not been killing engines early by the millions as the early anti-20 Chicken Littles predicted would happen. But common sense would seem to indicate that all things being equal (yes, yes, I know they never are...), the thinner oil is going to get where it's needed faster than a thicker oil.
I don't understand this way of thinking. You would rather give up HTHS protection for a thinner viscosity that has never been proven to protect better during startup. I see this "better startup protection" claim go unchallenged too much.
Well, on the flip side, there is no unchallengeable proof that a relatively higher HTHS is more important than the ability to flow quickly on start.
My own car has seen excessive wear going from a 50wt to a 30wt. I've seen it with my own eyes, not read about it on an internet forum.
Undoubtedly true, but don't overgeneralize from one data point (which you happen to own...
). Given the other info that's out there, I'd argue that your result is as much a result of the characteristics of your engine, as it is the oils involved. Because this result is not seen in mainstream vehicles driven under typical conditions.
BGN, obviously you and I have somewhat different views on this issue. Please don't mistake that for any lack of respect for your participation here. Have a good and safe weekend.
No disrespect taken and none given.
Of course I agree that thinner flows faster in theory but I'm interested when a positive displacement oil pump is thrown in the mix assuming it's not in bypass.
My GN is a bit different. One of my theories I have is I know the crank is flexing and the main caps have shown signs of walking in the past. My car likely requires a very thick oil due to distortion of the bottom end under power and the fact that it makes over 700lbs of torque at the convertor's stall speed of 2,800rpm spread out over only 6 cylinders... Couple that with a narrow bearing small journal crank and there's a lot of psi on the rod bearings.
On the HTHS issue, I'm sure you were around when the thread was posted with GM's testing on the 3.8L with different HTHS values. Wear was something in the order of 1/5 as much with a HTHS in the 3s than a 2.6. I have it saved on my computer at home. I'll post a link if someone doesn't find it first. I don't remember what the conditions of the test were, if it was normal load and rpm or if it was highly stressed.
As for the wedge, I see I was beaten to it already.
As it was mentioned, most rod and main bearings are very fragile. I can scratch them with a fingernail yet they sometimes come out of an engine looking like they have never been touched by anything.
Off topic but I wonder if the amount of VIIs can play a role in the time it takes to form the wedge...
Have a good weekend!
