Also, doesn't NASCAR require the use of certain viscosities?If they used Red Line 20W-50, the engine likely wouldn't survive the race. The hydrodynamic friction with the 0W-16 already contributes a 75°F temp rise across the bearing. The temp rise through the bearing (in those engines) is ~10°F for every 0.6 cP increase in HTHS. Their oil is ~2.3 cP and Red Line HP 20W-50 is 6.1 cP. The bearings would likely give way to fatigue from the friction and heat, that's if you can still get sufficient oil flow. They run way too tight of bearing clearance to run a 50 grade oil.
