Originally Posted by Gokhan
You keep talking about the "flavor of the month" (with regard to the three or four different oils I used in the last ten years -- so, you're off by two orders of magnitude, even if you're figuratively speaking), and you're the one who got started in this thread without replying to the OP but again criticizing my here-and-then varying oil choices.
NO I AM NOT...I was quite clear.
You resented
* uber VII as the ultimate selector of an oil, at the exclusion of all other metrics...and made authoritative statements and recommendations to posters based on your then 100 correct views.
* made authoritative statements regarding the search for higher basestock viscosity because your emphatic science was that higher basestock viscosity was THE thing in protecting engines.
* now it's PAO
* BOQI - and NO, that's NOT what the Chevron patent says.
* BOQI with HTS because BOQI doesn't work even in the same family of oils (demonstrating clearly the above point)
* Moly....must have lots of it.
You get a bee in your bonnet, misinterpret a couple of papers, then start making emphatic recommendations on what posters should be using.
I don't care that you think your clapped out Corrolla is the industry standard bench test for engine oil, nor do I care what you run in it.
That was not my commentary, it was about you flip flopping over "science", and your misunderstanding and misrepresentation of it...and changing the science you present over relatively short periods of time.
As to the trolling/my use of various oils....that's purely misdirection...look over there a bunny.
https://www.logicallyfallacious.com/tools/lp/Bo/LogicalFallacies/150/Red-Herring
