NEW FRAM ENDURANCE 3614 cut open
Looks like rust on the base plate and ridges/ruffles on the leaf spring. I really had high hopes for the Endurance line.
I think the earlier FE when it first came out were made better ... examples with smooth leaf spring stampings instead of ruffles. Same with the older Ultras. Champ Labs and Fram must be trying to reduce production cost by having the leaf springs stamped out in a dirt floor shop in some 3rd world country these days.
The way to fix this design is to take the extra step of applying a ring flexible heat resistant glue between the leave spring valve and the metal filter end cap.
The OG Ultra had a fiber sealing ring embedded in the end cap to seal the leaf spring. A filter needs to be leak free at that interface to maintain high efficiency, like the OG Ultra was. Whoever designed the OG Ultra put that leaf spring sealing gasket there for that very reason.
I don't get it either. The surface rust is on the dirty side of the filter and *if* the leaf spring lets oil bypass the media it will be minimal.
Time for this meme again, lol.
What a shame! Here, from a company that once had the nickname of “Orange can of death” to becoming one of the best **** filters ever made?
Typical company!
Putting their bottom line in front of their product. They deserve everything that comes from this!
edit: why is the word “d@mn” redacted?
Exactly. Fram knew that was a leak point even with nicely made leaf springs back then. Now we get ruffles with no seal.
Mountains out of molehills.
We know broken sloppy glue pieces have passed through a bypass valve in the past, rust certainly will too.
I’ve always said some people don’t mind the ruffles, I’m personally not comfortable with them. I don’t mind paying a premium for a premium product. But this is not a product built with care or attention to detail. QC is nonexistent.
Another example @THORROMIG found these at Walmart in unopened boxes. After finding 3 he stopped looking….on a positive note they won’t rust.
It's the BITOG way.
In most cases I would say this is just the typical overly obsessive response we see all the time around here. But this one has some merit IMO. It’s a premium/extended drain filter with noticeably more QC issues from C&P’s than many economy filters. If Mobil 1 Extended Performance started having more QC issues than Supertech Full Synthetic or QS FS - why pay more for Mobil 1 Extended Performance?
Would you be OK with a tear in the filter media that let 10%-15% of unfiltered oil constantly through the filter?
No. Are folks ensuring every cannister filter they use is ok? How do folks know without cutting them all apart? Where is an example showing one that has no light leakage like I'm seeing in the YT videos I'm watching? How does one know with certainty than X filter is ok and Y isn't?
No. Are folks ensuring every cannister filter they use is ok? How do folks know with cutting them all apart? Where is an example showing one that has no light leakage like I'm seeing in the YT videos I'm watching? How does one know with certainty than X filter is ok and Y isn't?
Buy filters without a metal-to-metal "seal" between the leaf spring and end cap (ie, filters with fiber end caps), or filters that use a coil spring instead of a leaf spring (like many of the Premium Guard made filters). That's how you get around the possible leaf spring leakage path.
The OG Ultra never had this issue because they knew how to stamp a smooth leaf spring back then, and the OG Ultra also had a fiber sealing gasket embedded in the metal end cap. Fram knew how to design and make a filter back before First Brands smoked them. Filter makers (including even Champ Labs) are getting sloppy with manufacturing these days to cut costs and make profits. The must literally be farming out those leaf springs to 3rd world manufacturing companies with dirt floor shops.
Oh boy when facts and truth come out the stuff gets mighty deep
