Smelling thin oil vapor can be dangerous!AI must have infiltrated ...![]()
Use a 60 grade oil, after all, it will have the least wear as it will have the highest MOFT. Your engine will last considerably longer. Now if fuel economy is a concern you can use a 15w40. But you will be giving up a considerable amount of engine life. This grade and any thinner grades are only CAFE related and should never be used unless you plan on selling you car before it gets to 50-60,000 miles. Using a 16 grade oil will only be a matter of time before your engine blows up.
Ali
Let's see what the owner's manual says:
Where's that 0W-8???
The 16 in 0W-16 indicates the viscosity characteristic of the oil when the oil is at high temperature. An oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions.
I'm guessing his rationale is because it's "watery thin" and like attracts like? Lol...Now someone on ToyotaNation is claiming 0w-16 "absorbs water" when you short-trip it in the winter time, and it's exclusive to 0w-16, not 0w-20, or heavier oils.
The part cut off at the end of the page is Toyota's standard OM statement saying that thicker oil is better suited or more severe use conditions. So Toyota is saying, even when they specify 0W-8, that a thicker oil can be used without issue.Here's your 0w8 requirement.
Best comment!!OW-20 is the new 20W-50
It's just standard crap writing from Toyota. But see in the circled, you can use a 0w16 if you can't find 0w8, but next oil change go back to 0w8, because by the time 10,000 miles have rolled around, you should have found some 0w-8 by then.The part cut off at the end of the page is Toyota's standard OM statement saying that thicker oil is better suited or more severe use conditions. So Toyota is saying, even when they specify 0W-8, that a thicker oil can be used without issue.
That statement is there a to basically satisfy CAFE.It's just standard crap writing from Toyota. But see in the circled, you can use a 0w16 if you can't find 0w8, but next oil change go back to 0w8, because by the time 10,000 miles have rolled around, you should have found some 0w-8 by then.
0W-20 is proven for a decade with no issues. I would start out with 0W-20 for a while, and then perhaps try 5w30 after that.So I just bought a gas 2023 Corolla with the 2.0 as a commuter. Toyota calls for 0W-8 oil for this. I’m fairly certain they made a change within the last month or so from 0W-16. I do my own oil changes and sourcing OW-8 seems about impossible. The manual does say you can use 0W-16 but it must be changed to 0W-8 at the next change. My wife has a camry that calls for 0W-16 and I would like to use the same oil in both. I’m aware of the car care nuts videos stating that these dynsmic farce engines need the oil grades Toyota calls for, and I believe there are threads here disparaging his claims.
I’m all about giving my vehicles the best protection. Does the Corolla really need this pathetic water oil, or is it just for CAFE standards and to get .1 better MPG? I doubt they would have made a mechanical change mid-year that would necessitate the lighter grade, or would they? Should I go even heavier for both vehicles at 0W-20? At least then I’d have way more options.
Any comments would be appreciated.
Why not do what Toyota says....They should know there cars...So I just bought a gas 2023 Corolla with the 2.0 as a commuter. Toyota calls for 0W-8 oil for this. I’m fairly certain they made a change within the last month or so from 0W-16. I do my own oil changes and sourcing OW-8 seems about impossible. The manual does say you can use 0W-16 but it must be changed to 0W-8 at the next change. My wife has a camry that calls for 0W-16 and I would like to use the same oil in both. I’m aware of the car care nuts videos stating that these dynsmic farce engines need the oil grades Toyota calls for, and I believe there are threads here disparaging his claims.
