Very low mileage vehicle oil change interval?
I have a very very low mileage 2013 Toyota Tundra. It only gets driven for the summer months each year. It gets driven anywhere from 1000 - 2000 km annually.
I generally change the oil & filter every autumn before it gets parked for 8 months.
Here is my question. I last changed the oil in October 2023. In 2024 due to medical problems the Tundra only made it on the road once for 100km drive. Today (July 2025) it is 21 months since the last oil change and the truck is going to be on the road.
1. I plan to change the oil today but don’t see a reason to change the filter. Any issue not changing the filter?
2. Does clean oil that sits in an engine for 21 months “breakdown” or gather debris or moisture?
It would be great to hear from some folks who have experience with low mileage vehicle maintenance. Thanks!
IMO Don't change the oil. Drive it. Give it a good 20-30 mile highway run if possible.
Change the oil and filter in the Fall
_______________________________________________
note: the PCV is open to ambient conditions by the vent hose from the air filter housing to the valve cover or valley cover. Never understood the reason some guys pull the DS or open the fill cap to "let in air"
I’m actually more concerned with the filter than the oil regarding the age to be honest. Oil filter construction and quality these days from various manufacturers can be hit or miss.
That said I’d change it with Supertech oil and filter. What are we talking about here like ~$40, yeah? As far as driving it around more, you’re gonna spend ~$100 in gas to save ~$40 worth of oil.
I’ve owned several personal vehicles that sit a lot because I had work vehicles as daily drivers. I’d always do an annual change on my bday month so it was easy to remember.
I have plenty of cars that get very low mileage.
Even long ago filters were wood for two years and 25k km/15k miles. For oil, if unused, the amount of moisture that could condense in there is pretty small, fuel is nil.
That said, it is worthwhile to get even environmental condensate out. But short trip use is worse by far. That said, a few longish trips, certainly longer than 20-30 miles, maybe 75-100 total, would be ideal. Then you can run a long time. Yes, the avoidance of short tripping can be a hassle, you can become a slave to that requirement. Which is why you’d then want to change the oil more often.
But I’d start with 24 months and a used oil analysis and go from there.
If it’s not going to be driven much in the winter months then it’s better to do the oil change before that time period as opposed to after
Why is that? The used oil is just going to sit in the pan in the off season. Then when you come back you change it before you start driving and it's fresh for the driving season.
Doing the opposite doesn't make much sense to me especially in the case of OP where life happens and you don't return to the car for 1-2 years. Why would you put brand new oil in at the end of the season and just let it sit there for years before you drive with it. I imagine the new oil would do better sitting in the unopened jug.
Because used oil is more acidic and can do more damage to the engine when it’s sitting for a long period of not being used.
And then that oil is basically still brand new for the beginning of the driving season.
I would change oil and filter 1X a year. Keeps fresher oil in it. Oil picks up by products of combustion, albeit a small amount in you're case. Patman is right, it picks up some acidity when just hangin out in the oil pan.
The oil in my F150 is approaching three years. That will be about 3.5k miles. I think I'll change it next year. Same filter for three years.
The oil has acid buffers, I don't think the oil turning acidic over the winter is a big issue on a low usage vehicle like the OP has. I'd leave the oil for two years or so.
As an aside, bringing older motorcycles out of long term storage is one of my hobbies. I've worked on several bikes that sat for decades. Pulling the valve cover to do valve adjustment, I have never one time seen a vehicle with any rust or abnormal storage rot attributable to the oil.
P1010283 by nessism, on Flickr
P1010284 by nessism, on Flickr
The best way is change the oil before you park the car in winter and do not start the car until the next spring. Low temp and idle creates water vapour that condensed and attacking engine oil. Especielly the ester additives, it got hydrolysis and becomes carboxilic acid.
It's been shown and said, ad nauseam, time and time again, when this question comes up, miles and not time is the better indicator of when to change oil. There isn't a major oil out there that can't be run for 1500 miles and parked for 6-9 months and then run for another 1500 miles the next year that's going to have any problem.
I had a 5,000 mile OCI analysis done on my motorcycle that basically sat for a year with only 325 Mi put on it in 15 months. No different than the previous ten 5,000 mile OCI's in terms of wear numbers, remaining TBN etc.
It's your money and it's your vehicle, however the data does not back human emotion.
The Car Care Nut (generally well regarded Toyota/Lexus YouTuber) says modern Toyota/Lexus engines are well sealed allowing moisture to build in the oil. He says change every 6 months regardless of low miles. Also said oil analysis is accurate but problem is getting representative sample. There are dead spots in the system where moisture may be much higher than pan.
That advice goes against that of every manufacturer of motor vehicles on the planet.
