What about the U.S. military burning millions upon millions of barrels of fuel daily?If you use 0w16 oil, you'll kill the environment and waste precious resources.
Exactly why I do my own oil changes.I’m not losing any sleep over it either, bud. In my experience, Toyota care sucks. Between wasting hours at the dealer, dealing with oily hand prints on my seats (it’s happened to me on a prior vehicle), over tightened filters and plugs, it’s far easier to do it myself.
No difference between 0W-20 and 5W-20 in the summer. Go 5w30 for hot climate.Probably even 5W20 at some point during spring/summer months.
That is a sharp looking wagonSince when is Mobil 1 Full Synthetic 0w40 thick? It used to be labeled as an Energy Conserving motor oil... way back ... when.
Now, who doesn't like a SportWagen in brown?
My daughter just got a '23 Corolla. What oil filter does this call for?So I just bought a gas 2023 Corolla with the 2.0 as a commuter. Toyota calls for 0W-8 oil for this. I’m fairly certain they made a change within the last month or so from 0W-16. I do my own oil changes and sourcing OW-8 seems about impossible. The manual does say you can use 0W-16 but it must be changed to 0W-8 at the next change. My wife has a camry that calls for 0W-16 and I would like to use the same oil in both. I’m aware of the car care nuts videos stating that these dynsmic farce engines need the oil grades Toyota calls for, and I believe there are threads here disparaging his claims.
I’m all about giving my vehicles the best protection. Does the Corolla really need this pathetic water oil, or is it just for CAFE standards and to get .1 better MPG? I doubt they would have made a mechanical change mid-year that would necessitate the lighter grade, or would they? Should I go even heavier for both vehicles at 0W-20? At least then I’d have way more options.
Any comments would be appreciated.
Shhh… there will be no more Mobil 1 0W-40 left for the rest of us to support our 3k mile OCIs.What nobody recommending Mobil 1 0W40 Euro yet? BITOG thickies slipping.
Because Toyota hates the environment, it gets one that is disposed of in a landfill and not washed in a parts washer.
Amazing. Entir Facebook group for diesel brown manual station wagons.Since when is Mobil 1 Full Synthetic 0w40 thick? It used to be labeled as an Energy Conserving motor oil... way back ... when.
Buy 0W-8 from @High Performance LubricantsBuy 0w-8 from Toyota.
4AFE engine ones will, I don't know about the other ones15W-50. Or just whatever they list as acceptable in the manual. It’s a Corolla, it’ll run on anything and outlive most cockroaches.
Problem solved, that only took 53 posts! LOL
Get those first two OCF gratis at Toyota. Stick with OEM manual recommendations-I suspect there may be a bit of wiggle room for the viscosity. Otherwise, key are frequent OCF in conjunction with your other preventative maintenance. 5K miles for a daily driver isn’t too much. The car will thank you.So I just bought a gas 2023 Corolla with the 2.0 as a commuter. Toyota calls for 0W-8 oil for this. I’m fairly certain they made a change within the last month or so from 0W-16. I do my own oil changes and sourcing OW-8 seems about impossible. The manual does say you can use 0W-16 but it must be changed to 0W-8 at the next change. My wife has a camry that calls for 0W-16 and I would like to use the same oil in both. I’m aware of the car care nuts videos stating that these dynsmic farce engines need the oil grades Toyota calls for, and I believe there are threads here disparaging his claims.
Beware the Indiana (TMMI) and Kentucky (TMMKY) Tototas. TMMTX ones may be okay. The Japan and Canada ones as well.
@PimTac you beat me to it lol.
Toyota probably uses Idemitsu but having worked there.. I wouldn't trust that it is Idemitsu over some Highline Warren manufacturer along the supply route to keep production going . Quality? Ha..
