Originally Posted By: JoeWeinstein
No, let's say I'm running the correct viscosity for my
motor... No one should run thicker, just to stop
consumption. That's like turning your blood to jelly,
to stop a hangnail from bleeding.
I'm surprised my TL is still running with that Jelly going through it's veins.
I am only saying that you should run the viscosity
recommended for your engine, and not put in any
thicker oil, just to stanch a symptom. If 20w50 is
right for your car, that is what you should run,
but if it was supposed to use 10w40, and now it's
older, somewhat tired etc, I don't think you want
to thicken your oil. It may stop consumption, or make
the valve train quieter etc, but I worry that it
will still cause extra wear, at startup when thin
oil is good, and also may not adequately lubricate
those parts of your motor that still have the original
gaps that require the thinner oil. For instance, in
trade for less oil past your worn rings, you may also
be getting less oil through your still-OK main bearings...
I wouldn't sacrifice or jeopardize my bottom-end for
any savings of a qt. per 1000 miles. I'd either get
my top-end rebuilt or live with it.
You don't want pressure, you want flow. Viscosity
is liquid friction, a necessary evil to be accepted
only as much as necessary. Formula 1 engines use very
thin oils, like straight 0-wt. Do what the manufacturer
says....
So, back to the original question; and it's sounding
like if the oil qualities are such that it's perfectly
adequate at 2500 miles of use (assuming the motor's
blow-by etc does not unusually dilute or use up the
oil's additives enough to defeat the oil's normal
recommended life) it sounds like the idea is not wrong.
Joe
Going up one range in viscosity won't hurt a thing. I run a higher than recommended viscosity in all of my cars, always have and not once have I had a problem.
If you had ever watched how quickly an engine gets oil pressure, even with thicker stuff in the winter, you wouldn't be worried. With a 20-50 in my GN, oil is coming out of the valvetrain nearly instantly. Oil is coming out of the turbo feed before I release the ignition key.
As long as if flows ok, you're fine. I believe the thin stuff is primarily for fuel economy while warming up.
