I've owned both. Here's the rub with turbo's and trucks, weight. You have a Ford F-150 with a six cylinder turbo and want to use it as a daily driver and never really haul anything or tow a boat or trailer, you'll never have any issues. You use that same truck as a work truck filling the bed daily with hundreds of pounds of materials or for towing your a boat or trailer every weekend you will eventually have issues with the six cylinder turbo motor.
With the way engines are built today you'll never see any problems if your changing vehicles every 80K miles or less. The issues start coming about when the miles start adding up over the years. These turbo four and six motors aren't going to last like a NA or even a turbo V8 would in a heavy truck application.
Do you think any of that could be solved by education? What I mean is, turbo motors, even today's with the advanced control systems and better lubes, can probably still benefit from some old-time turbo habits, such as.
- Letting the turbo cool down for a few min after being worked hard
- Changing the oil more often
- Being easy on the motor until things are up to temp
- Using a higher octane gas than recommended*
- Avoid excessive idling
- Make sure to work it hard now and again to keep the variable vanes moving properly
*Ford specs 87 octane for my truck, I don't think I'll ever be comfortable using that, certainly not if I plan on working the truck hard.
I think a lot of problems today are driven by a 'non car' userbase. I've mentioned this before. People today treat cars/trucks like appliances. They want to get in and go, stop to fill up with gas, and take the vehicle for maintenance sometime around when it tells them to. There's no mechanical sympathy or any understanding of how the vehicle works. They expect the vehicle to monitor itself, not let them do anything that would seriously hurt it, and tell them when something is wrong, end result, the vehicle lasts until the extended warranty is up.
I'd bet, you take 2 theoretical identical BITOG'ers give one a NA truck and one a turbo truck and you get the same life out of both, barring any massive engineering problems or faults in the vehicles.
