^^^ I have a theory.
there’s a lot of posting about ecoboosts running hot when towing. Now, granted, these may also be the same drivers who feel that towing heavy trailers should not interfere with their inherent right to climb steep grades at 5 over, as there seem to be some out there.
theory - on a big bore motor, there’s a lot of piston surface area, and there are larger cylinders, and more area exposed from piston to block and block to water jacket and water jacket to coolant. There’s all this surface area to keep heat from 1ATM of combustion out of the chamber into the coolant. But in say mine, it’s a smaller piston, cylinder wall, cooling jacket and exposure to coolant. Call it “half” the surface area, for the same amount of work. ive wondered if the physics simply can’t provide the heat transfer needed, even though the power is there.
this would also explain why Ford might keep the 3.5 around.... maybe it can get more heat out a little better?
m
