has officially become the most reliable car I have ever owned. Did I just get lucky?
Compared to the other three cars you have listed, it's like a Toyota.
You will love it. I almost bought a new one in 2015.
Is it pure white with a pointy appendage sticking out the front?has officially become the most reliable car I have ever owned. Did I just get lucky?
I know some who consider water pumps, timing chains, and turbochargers every 50k-60k a maintenance item. And stuff like failed seals/gaskets just gets brushed under a rug. While for example Honda J-series gets a stinky eye for needed a timing belt and valve adjustment once in 100k miles...What work has been done to it? Some people say their car hasn’t needed anything but maintenance. But then fail to mention they personally consider control arms, alternators, etc. as maintenance
To my surprise I have not replaced a single component in the front suspension. I did put two shocks in the rear because they were rusted. I did the timing belt and WP service at 150,000 miles. I’m on my third battery. It does eat tires at an alarming rate. I had a few oil leaks repaired. I use full synthetic and change the oil every 7500 miles. I bought the car for $12,000 back in 2012 with 600 miles on it. The body is starting to rust.What work has been done to it? Some people say their car hasn’t needed anything but maintenance. But then fail to mention they personally consider control arms, alternators, etc. as maintenance
I guess the old saying Fix It Again Tony was wrong. All kidding aside congratulations and good luck going forward.has officially become the most reliable car I have ever owned. Did I just get lucky?
