The GM issue only surfaced in recent years.
HEMI issue has always been around.
From what I recall, the HEMI issue appeared when the lifters changed when they introduced VCT to the engine. The early MDS engines without VCT, like the one in my wife's former '06 Charger, didn't experience the problem.
Ford, GM and FCA (now Stellantis) have all had tremendously poor durability from their roller lifters, which tends to trace back to poor/inconsistent quality, likely having been outsourced to China.
Also, lifter failures with the LS aren't only a "recent years problem", here's an LS2 with one, in the comments, guy with an '05 CTS-V has the same problem, and an '07 LS2 'vette also mentioned:
It became much more common with AFM and got worse with more recent revisions of it. Melling released this TSB in 2018:
SMALL BLOCK & BIG BLOCK OIL PUMP OPTIONS (melling.com)
2007 thread:
How to tell you have a bad lifter? | LS1GTO Forums
Early (pre-AFM) GM "lifter failures" were often caused by the plastic guides failing.
Here's the NHTSA notice from GM showing affected years of 2002 to 2018:
19-NA-219 1..4 (nhtsa.gov)
Based on this, GM's issue pre-dates FCA's considerably.
