Usual failure mode on a cam and lifter failure is the roller on the lifter fails and wipes the lobe off of the cam. Chrysler has a service bulletin instructing inspection to determine if cam and lifter replacement is viable or if the engine needs replaced. Basically you pull the intake manifold, remove the VVT solenoid and MDS solenoids and look for metal on the screens, If there is metal on the screens the engine gets replaced. Before I go that far I usually take an oil sample and look for glitter. If theres glitter in the oil there isnt much point in checking the screens.So I guess I could have googled, but the roller is in the lifter, and it appears replacing lifters is a heads off affair, so a pre-emptive replacement is a ton of work as well. Not a great design, or at least not a design conducive to repair unfortunately.
A few months ago I did an engine in a Ram of this vintage, misfire on cylinder 5, failed the exhaust cam lobe and lifter. Oil looked like silver metal flake paint so no point in yanking the intake. Between a Chrysler reman engine, all the bits required to be replaced for warranty plus some stuff that was pointless to reuse on a 250k truck while it was already removed (radiator and hoses, exhaust manifold, some engine management parts, etc) We were right about 13k out the door. Guy couldnt replace it for that and took all of 30 seconds to approve the job.
