The investigation may be closed, but it still raises many questions. We know that an empty gallon MMO bottle was found in the trash and that, at minimum, the person who added it, added a dose at least 4x higher than what Marvel recommends. We also know the engine showed signs of either excessive wear and, or, internal damage.
We don't know the maintenance history of the engine, or the degree to which MMO was used on it in the past (as in this may not be the first time an MMO OD was given to it). In short, there is too little information to conclude that MMO was the cause, or even a factor in the plane crashing. All we know is the engine failed, and on its final flight it was dosed with 4x the amount of MMO.
Bluestream, you say you are a pilot. As a pilot, you should know the importance in measurement involved in all calculations, particularly those related to fuel. And given this, you should also realize that adding 4x the amount of MMO recommended is way past any fudge factor, and amounts to gross negligence on someone's part.
The only thing I can conclude from what we know is that if MMO played any role (a big if still), it was not simply the addition of it, but the massive OD of it that far exceeds the recommendations of marvel. This in no way reflects upon the product itself; it does reflect on the competence of the person who added it though.
-Spyder
