This sounds like a solution to a problem that does not exist.
Now, mixing windshield warsher fluid, that's batcrap crazy, right?
What problem doesn’t exist?This sounds like a solution to a problem that does not exist.
Our GS350 F Sport (not aneconobox by any means) specs 0w20. Last time it got a jug of 5w20 and a quart of 0w20. The shame!My Chevy 5.3 gets a 5 qt jug of Valvoline HM 10w30 in its 6 qt sump and 1 qt of NAPA 5w30 synthetic I bought on sale at every OCI. Simply because I refuse to buy 1 qt of the Valvoline at $6 a qt to finish filling the sump. I’ve done this for years and my truck just rolled over 226,000 miles and runs as good as it ever has with no oil consumption. Yes, I could buy 2 jugs of the HM 10w30 and have a partial jug sitting on the shelf for years but I just don’t.
Engines damaged by adding a make up quart of different oil.What problem doesn’t exist?
Not a problem if they’re the same brand - your econobox won’t know either way.Our GS350 F Sport (not aneconobox by any means) specs 0w20. Last time it got a jug of 5w20 and a quart of 0w20. The shame!
Didn’t say engines would be damaged.Engines damaged by adding a make up quart of different oil.
In this case, the brands were both Mobil 1, but the 5w20 was high mileage.Not a problem if they’re the same brand - your econobox won’t know either way.
Agree that the chemistries are mixed and therefore changed. That does not necessarily mean degraded; it may be improved. Or it may be insignificant.Didn’t say engines would be damaged.
I did say that oil performance could be degraded.
Ask Molakule. Ask HPL.
With just a slight tweak in chemistry, it sometimes happens that the oil foams up, or changes pour point, of viscosity, or fails any number of the required tests.
It’s degraded, in other words.
But you really have no way of knowing if that happens in your engine because you can’t see and can’t test the performance of the resulting mix.
You might be fine.
You might not.
Agreed, except possibly if you consider there seems to be no studies showing a problem using a different top off oil.Think about what one would need to know to answer this, and you'll realize practically no one can answer it legitimately.
Imagination is not required. That's why licensing requirements and ASTM D6922 exist.Think about what one would need to know to answer this, and you'll realize practically no one can answer it legitimately.
Astro, question for you. If there were a meaningful issue, don't you think there would be a warning printed on the oil container, or perhaps on an engine's oil fill?Didn’t say engines would be damaged.
You might be fine.
You might not.
The issues related to refined sugar are well documented.Do people analyze the food and drinks they put into their bodies to this same degree... Or do they just shovel all kinds of overly processed, sugary garbage down their gullet with reckless abandonment...
