- Joined
- Mar 10, 2023
- Messages
- 184
Last time I was in there the STP XL in the shelf was a PG made filter. Almost identical to the Oreilly Microgard Select.Autozone sells these too, but not sure if they use theses or Champ anymore, check COO.
I've never seen a rusty filter before (and I live in a rain forest). Huh.I wasn't that thrilled with it. Metal shavings came off the threads and ended up on my magnetic drain plug. Also never had an oil filter rust like this. Very much hoping my engine is okay.
I'm going back to OEM.
Metal shaving at the tip of my thumb.
View attachment 289284View attachment 289283
How would a person know after the fact where a metal shaving came from?Surface rust on unpainted crimp is a non issue. Metal shavings would be from the threads. Inspection before installation is a must on every brand.
True.How would a person know after the fact where a metal shaving came from?
Yes. PGI made filters and Pentius filters have the most consistent quality currently. Very very rarely do I see problems.I visually inspected the Oreilly Microgard and NAPA Gold filters I bought. I did not see any metal shavings nor other issues. That said, visually checking is a good idea because it could happen with any brand of filter.
They couldn't. Everything seen on a magnetic drain plug is pretty much a mystery of where it actually came from.How would a person know after the fact where a metal shaving came from?
sheeez purdieI just changed my oil & filter on my 2001 LeSabre. This time, I went with the Microguard Select (Always been a WIX fan) and I must say... for $11 it's a very nice, well made filter.
It came plastic wrapped and what I liked was the larger inlet holes and "holes" instead of louvers. (Just personal preference). When installing, I liked how the filter made contact with the gasket and it snugged-down really nice. (I've had WIX filters sometimes hit the bottom of the can.) Nice thick gasket on these.
I'm not going to get into efficiency specs and all... but based on what I can see and feel, this will be my new go-to filter. I don't understand why it's not getting more 'love'.
View attachment 143650View attachment 143651
I thought so. I'm trying to make a point by asking the question. I assumed the answer would be as you and others have stated. Hopefully the OP sees the point I'm making.They couldn't. Everything seen on a magnetic drain plug is pretty much a mystery of where it actually came from.
There's no way he could know if the metal flake came from the filter threads because he didn't check the threads before installing filter. So I don't think it's accurate to assume the filter is the source of the flake.
9 months 4k miles.My apologies, I didn't take photos, but there were some similar flakes around the threads of the filter itself, and if you zoom in on the photo, you can see a scalloped area of the threads still on their filter.
To each their own. I wasn't overally impressed. I live in the Northeast, and in 20 years of changing oil I have never seen the rust or the thread issue. Could be one bad batch of tap from PG.
The replacement in the background said you were not.I'm going back to OEM.
