"Handling" and "performance" aren't simple things that go up or down with tire width. Each of those terms describes a collection of attributes. Some of those attributes (e.g. lateral grip) get better with more width. Others (e.g. longitudinal grip, limit behavior) get better with less width.
In other words, if you're avoiding a narrower tire because you want to "retain performance" or "maintain handling," you're not getting the whole picture.
ICYMI -- pasting because I don't feel like reformulating something I've already posted:
Originally Posted By: d00df00d
There is exactly one performance attribute that is better for a wider tire: peak lateral grip when driving on a smooth, clean, solid surface (i.e. cornering on a dry road or bare sheet ice).
Longitudinal grip (for acceleration and braking) may or may not be better. Going wider while keeping the same overall diameter yields a contact patch that is wider but not as long front-to-back.
Mass, hydroplaning resistance, rolling resistance, limit behavior, tramlining, feel, NVH -- in other words, pretty much all other attributes that matter -- are all worse for a wider tire.
Tire width is a lot like oil viscosity, honestly. You want as much as necessary, and no more. There's a reason cars built from the ground up for handling -- Miata, BRZ/FRS, RX-8, etc. -- don't come with steamroller tires. There's a reason performance cars rarely have the widest tires that'd fit, especially in front. There's a reason the Mercedes S65 AMG "only" has 285-section rear tires with 738 lb-ft torque while sports cars with half as much engine have 305s or more. The engineers who make those cars generally know what they're doing.
Regarding your particular case:
1. What the set of OE tire sizes shows you is that 195 is the baseline for the Corolla, and 215 is two sizes up from that. From that perspective, 185 isn't 30 down from what the car was designed for; it's 10 down.
2. Never forget that you'll be running a tire that's more suitable to winter temps than the stock all-seasons are. The OE tire on your car is... decent, I'm sure, but ultimately a totally unremarkable all-season tire. In winter temps, even on bone dry roads, it'll get crushed by a winter tire -- even if the winter tire is significantly narrower. I'd bet you probably wouldn't lose much lateral grip in winter temps by going to a 185-section winter tire, and there's a chance you might actually GAIN longitudinal grip. So, if maintenance is what you're worried about, there's no need to stick so close to the OE width. In fact, on cold dry roads, a 205-section winter tire would likely be an UPGRADE over OE. Nice, sure -- but unless you hate how your OE tires grip on dry roads, why not shift the balance more toward rain/snow/slush?
3. Don't worry about your rear disc brakes. The limiting factor for wheel diameter is always the front brakes, not the rear.
4. The comparison between the X-Ice Xi3 and Blizzak WS80 has been pretty substantive. It's one of the areas in which I don't think edyvw is wrong. :] If you want to prioritize traction in slush or very deep snow, you might want the WS80. Otherwise, you want the Xi3.
5. Here's another thing everyone seems to agree on, regardless of anything else: if you throw legit winter tires on your car, you'll be making a big improvement no matter what size or model you settle on. That doesn't mean all options are equally good, but it does mean you don't need to lose sleep over this. Pick something, give it a shot, and get back to us with a review.
