Originally Posted By: NissanMaxima
1. It seems folks feel the Blizzaks are superior in deep snow to the Michelin X Ice 3 but are "mushy" on dry roads. What do folks mean by "mushy"? Since there are plenty of dry days in winter in Denver, I'm not sure whether to opt for the Blizzaks (and get the superior deep snow traction) or the Michelins (and get an apparently better dry road behavior).
When you steer, you want the car to react in a positive, crisp, predictable way. What you say here suggests that the X-Ice Xi3 is better in that respect.
2. I read somewhere (and wish I could find that link now) that steel wheels are better in winter because they are heavier and lead to less "rebound" and therefore punch through the snow better. Yet, tire rack was baffled when I asked them about that AND the weights of the steel wheel they have vs. the alloys wheel (which I prefer) is actually about the same - about 22 pounds. Any comments on this?
The snow thing sounds like bunk.
If the weight is the same, get the cheaper wheel. But you should be able to spend just a few more bucks per wheel and get lighter alloys.
3. Regarding wheel size for my winter tires, I understand minus sizing is a good idea. I was planning on minus sizing from my stock 17" to 16" because I can get the Michelins in a 195 55 16 with 24.4" diameter (their 15's are 205 60 15 with 24.7" diameter and I thought the increase from 195 to 205 wouldn't make sense). However, with the Blizzaks, Bridgestone said a 195 55 16 with 24.4" diameter or 185 65 15 with 24" diameter would work. I understand that my stock 17's with the 215 45 17 have a 24.65" diameter and both manufacturers made their recommendation to stay as close to stock wheel diameter as possible. Therefore, should I favor the Blizzaks because I can get down two sizes to the 15's and a 185 or would either brand choice in the 16's be adequate?
Tough call, but staying close to stock OD is important. If there's no 15" size that'd get you closer to a 24.65" OD, I'd go for one of the 195/55/16 tires. I'd go Michelin, but the Blizzaks should be good, too.
4. Finally, regarding my three season tires, I think I should stick to the OEM W rated tires. I think I narrowed it down to the Michelin Pilot Sport AS 3 plus and the Conti DWS06. It seems the Conti's have a better proven snow performance (in case they are on the car before I get my snow tires swapped over) but the Michelins have better ride quality and perhaps wearability (many reviews on tire rack mentioned quick tread wear on the Conti's). Any preference between the two or is it time for a coin toss here? I also looked at the Dunlop Signature HP one member mentioned but this tire didn't seem to get the same high marks as the other two choices mentioned.
Michelin, no question. With a winter set, the DWS06's margin in the snow is useless.
