Originally Posted By: Farmer
Onug, that's a spring to keep the filter pushed up against the base plate.
Thanks! So if it's damaged, you have the potential for the filter to not seal correctly and I assume oil could possible flow thru the canister without going thru the filter. Correct?
...new guy still learning here...
