I see a lot of people looking for oils that meet 10K and 15K Man. OCI requirements. Why not just change your oil at 5K or 7.5K and be safe?
I think its done for various reasons. Some folks don't like to change oil, some run that long bc they don't realize oil must be changedquote:
TS:quote:
Originally posted by TooSlick:
John,
It's an empirically derived constant; based on the oil analysis results I've collected over the past ten years using Amsoil. Note that this data was generated using Amsoil recommended practice of changing the filter and topping off the crankcase after 12,500 miles/6 months.
For the Amsoil 5w-30/10w-30/10w-40, I use a C* of 120....
I should add that the units don't cancel in this formula, which I know bothers some of my fellow mechanical engineers. So just use the numbers by themselves.
Ted
I'm not TooSlick, but I'd say you'd replace that 120 constant with a lower number, resulting in a shorter OCI. If your oil rates a "5" and the Amsoil a "9", I'd say that "5" is equal to 66.6666.quote:
Originally posted by Shaun:
TS:quote:
John,
Ted
How would we adjust the 120 for an oil inferior to Amsoil?
By this I mean that if we look at Amsoil to rate a 9 out of 10, (leaving room for inevitable improvement), and we rate a hypothetical oil a 5 out of 10, would I replace the 120 in the equation with a higher number or a lower number?
I might could believe this for a gas engine, but what is C for a diesel? for my engine this formula is:quote:
John,
Ted
