M1 0w40 or EDGE 0W40
In the shop
Good afternoon folks. The consumption has dropped a bit on the Camry I have. A co worker had some Mobil 1 0w40 and like 4 quarts of EDGE 0W40 he didnt need. Said he sold his Mercedes and now has a 2017 Hyundai Santa Fe. Which 0w40 would you use for my car? Nothing to lose as car runs great considering it's just shy of 170k now. Discuss
Both
But I am a huge Castrol 0w40 fan, so Castrol
Originally Posted by BeerCan
Both
For conversation sake; which oil has a better add package? In terms of zinc and phosphorus and boron and moly?
The oils meet the same specs so the performance is, for all intents and purposes the same. Use either with confidence.
You people that can predict the future performance of a motor oil based on a Blackstone VOA/UOA are amazing, especially when comparing two oils with identical or nearly identical approvals and specs. I sure can't do that
Originally Posted by krismoriah72
Both
Edge VOA https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4510746/1
Mobil VOA https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4225470/1
Man, that M1 0w40 one us so blurry even if I was 20 i couldn't make out the additives
Help me understand, is your coworker giving you the oil or are you buying it from them or are they giving you a choice and you are trying to decide what to get? If they don't need it why not just take or buy whatever they have and use it?
I like the edge.. Run that first, then run the Mobil second!
Hyundai generally allows the use of 5w20-5w40 does your coworkers Sante Fe not? He should have ran the 0w40 in the Hyundai.
Anyway, nice score for you!
Application dependent. You wont know until you run both. My '07 M-B E-Class had less consumption with Castrol v. Mobil 1 0w-40. Castrol was a quart per 6k and M1 was quart per 4k.
My 14' Audi A4 is almost same with either.
Thank You for the positive info
You are welcome.
I couldn't tell any difference in the M-B between the 2 other than the burn rate...that's why I mention it as the only comparison point. I bought what was on sale. Just M1 (historically) was easier for me to source. I was doing jug and quarts so I didnt have a lot of partially full containers in the garage (filling with 8 quarts).
Originally Posted by aquariuscsm
Run the Edge first,then do a uoa. Run the M1 second and do a uoa.
Then post the comparos :^D
I concur about Edge first. Perhaps; you can run both and give us an anecdotal update with your favorite and/or thoughts. Good luck sir!
You are the Master of Oil Filter Photography. MOFP!
Both
*Castrol 0W40 = Titanium but no Moly ... M1 0W40 = Moly but no Titanium
If I'm waiting at the drs office perusing BITOG and I see a new Stude C&P, i look over my shoulder just to make sure nobody's watching!...‚...‚...‚
[Linked Image]
Not just you, even with my bifocals I can't make it out....‚
I tried googling a UOA for 0w40 and the most recent I can find is like 5yrs old...not sure if that would still even be the same formula in use today. I guess just pick one and run it?...are you planning on doing UOA's?
