I use M1 0w40 in ALL my engines that require 5w30 to include my Hyundai GF4D GAMMA GDI, best oil I have found for such usage.
VQ's are not the quietest engines, and if are 'lucky' enough to drive a nissan manual transmission, you will be thankfully the engine isnt as loud as the trans. The nosiest 6MT I have ever driven.Just switched to 0w-40 in my VQ35...very early on but initial impression is it's a little quieter. Biggest factor for me was knowing the chains on the VQs are shear monsters. In my J35 that specs 0w-20 I am running 0w-30 for a little extra fuel dilution protection.
Current 0W-40 products have shown superior viscosity retention over the previous Mobil 1 0W-40.A 0w40 probably becomes a 5w30 in no time at all from shearing the VI's.
Run two tests. Run each for about 16km (10kmi), UOA them each, see where their final viscosity ends up.
Beyond that, if you're using Blackstone for a UOA they cannot tell the difference between fuel dilution and actual mechanical shear, any viscosity deviation they may point out is not something they can conclusively determine.
I assume Pennzoil is probably mostly GTL, and Mobil1 seems to be a blend of GTL with some PAO.Exactly this. I remember sonofjoe speaking about this at some length. Also would be surprised to see any 0w-40 with a decent slug of PAO in the base oil blend slip a winter rating, perhaps 0w-40's in general, given they typically use a pretty light base oil blend.
That's on the edge of cowboy, no? Won't the 40 be too thick at temp if the manual says to use 5w20 and 30 is "acceptable"?I've run 0W-40 in my 2017 Hyundai Elantra that calls for 5W-20 with 5W-30 being acceptable, my GM 3400 engine, as well as numerous Maximas which have all called for 5W-30. No problems in any of them.
I never said it was too thick, but a 40 will be thicker than a 30 at temp, no? The maker of the engine perhaps says 40 is too thick by specifying use of a 20 with a 30 being "ok". Since 40 is not mentioned by the manual then perhaps they don't mention it for a reason?How can the oil be too thick at temp if it thins with heat?
The diff is in the English though. I did not make the statement as a point fact, I asked a question, even used the "?" mark too.Words have meaning.
