LSJr. The TRUTH About Valvoline's BOLD Engine Cleaning Claims
I use HPL, and I just changed my son's car and used the Valvoline restore and protect in it.
I hope you share the results both good and bad as time goes on.
Let me be clear though, HPL is a good oil and in the past as I have mentioned it is especially good for heavy duty towing and performance applications. I am just pointing out the hypocrisy on here by fanboys.
Folks like teamsports. Just strange to choose corporations as the banners to fight for.
He attributed some of the deposit buildup due to high moly of TGMO. I say it's inconclusive that the high moly caused it, but I have read high moly levels are not ideal for deposit protection. If you have the solvency built into your oil, it's probably not a concern at all.
I can't see moly creating varnish. Piston deposits maybe? (TEOST anyone?) but I can't envision a mechanism through which moly creates varnish, given what varnish is.
Not everything Lake says makes sense either. This Moly connection and the manganese connection (due to cleaning carbon), don't make sense. Maybe Dr. @MolaKule can chime in on these supposed connections...
He said the spike in manganese is proof that it is dissolving ring deposits because it's manganese is found in octane booster found in fuel. He's saying that is proof Valvoline Restore and Protect is cleaning the ring grooves. Releasing old deposits. I should have specified and it wasn't just about the varnish. So he's thinking long drains with high moly oils = deposits. TEOST does reflect that as well but if I remember correctly, it wasn't fully proven.
@OVERKILL See post 37
I have checked half a dozen of used oil analysis and most of them don't have that manganese spike.
He said the manganese came from nowhere else, so it could only be from rings. Not sure I buy it, but it's plausible.
He does have a lot of experience from JGR.
What as the Mn level in that sample he showed? I had 9ppm in my last UOA where it's normally zip.
The only way to know for sure is to do a metallurgical analysis of piston rings.
"Steel contains about 1% manganese, and the Manganese is efficient in boosting the quality and functionality of the steel. Manganese-steel combo contains approximately 13% of Manganese. It is extremely solid and is used in the manufacturing of rifle barrels, railroad tracks, and jail bars."
https://allusesof.com/elements/uses-of-manganese/
https://www.mahle-aftermarket.com/m...and-literature/pistons-and-rings/pr-40-22.pdf
It was only 7ppm. So not very convincing.
He did said he never had manganese that high before and none of the other vehicles do as well. He also puts the same gas in. 🤷‍♂️ know...
Every time that Lake Speed lickity split guy makes a video it creates naked bloodsport foosball here. I'm not a huge fan of his, find the click-bait and his overall delivery not to my taste. Doesn't mean I don't think he is truthful or invalid, but I don't like the titles. I guess he does it to garner clicks. It is a business and source of income for him after all. Just not my "cuppa" tea.
This is very close to the value I had and the same, never had it in any UOA I've done over the last 6 years in that car...only after the longest HPL run I've done....
Edit - see below, I mispoke...I've had a few times...
Just looked through all my used oil analysis for the Sportwagen. For Mn, I've only have a few hits above 0/1 ppm over the 6 years worth of data I've collected, see below:
7.8k mi - 6ppm Mn, initial fill (Castrol 0W30)
73.2k mi - 24ppm Mn, this oil was in when the timing chain tensioner failed but I was not aware yet (LM Molygen 5W40 + HPL engine cleaner as I was getting ready to start running HPL)
77.3k mi - 4ppm Mn, continued to drive with failed timing chain tensioner (first run with HPL Euro 5W40)
108.4k mi - 9ppm Mn, 8 track days/8.4K OCI (longest/harshest run with HPL Euro 5W40)
Sure seems like a pattern here......cleaning oil and Mn....hmmmmmmm I think ol' LSJR is onto something here...smash that like and subscribe! I knew $800 worth of used oil analysis was well worth the price paid to be able to be in this discussion 🤣
Edit. The plot thickens! Whoopps...forgot that the the 73.2K data included me running Lucas octane booster which is the likely source of the Mn in that sample which turned my spark plugs orange as I remember...hahahahaha
Might have to try it out on my old chevy 4.3 vortec! Its only got 110k miles. I'm the second owner, and the lifter valley was pretty nasty last time I replaced the lower intake gaskets. This oil might clean it out some.
