- Joined
- Jan 12, 2025
- Messages
- 62
Valvoline Restore and Protect has lovely before and after pictures of pistons on the bottle label. One is dirty and the other looks nearly new. The text says:
Removes up to 100% of deposits with continuous use*
*With continuous use. In adapted sequence IIIH testing piston deposit removal
While I'm not questioning the results of that particular test, I do wonder how relevant they are for cars which are driven normally. That sparkly clean piston would presumably have free rings, particularly oil control rings. A lot of people with cars burning oil are using Valvoline Restore and Protect now. Yet the number of claims of "my car no longer burns oil" are very scarce. Search for:
"Valvoline Restore and Protect" stopped oil burning
and there are a couple of claims of complete success, a few of partial success, and a whole lot of "well, let's keep trying." It doesn't inspire much confidence that Valvoline Restore and Protect can resolve an existing oil burning issue, although it may surely help in preventing one from developing.
People might argue that oil burning is mostly due to other causes, and some of it surely is. However, that stuck rings is the primary issue is pretty well established. Fixing that is hard. The most complete saga I have seen on that is a very long string of videos where a person tried pretty much every sort of chemical repair possible, including Valvoline Restore and Protect, to stop oil burning in a Corolla, and then finally fixed the problem with new pistons and rings:
Nobody questions that Valvoline Restore and Protect pulls the varnish and other such carbon based yuck off many parts of the motor. For instance, it definitely cleared the varnish off out 2007 Prius's dipstick. However, I have yet to see a change in oil consumption, and it is now at the the end of the 2nd Valvoline Restore and Protect interval. As noted above, releasing stuck oil rings chemically is a hit and miss, mostly miss, proposition.
All of this makes me wonder if the pistons in that IIIH testing are that clean because the test itself is ideal for the functioning of Valvoline Restore and Protect. However it is a poor model for the piston environment inside typical engines. Consequently expecting Valvoline Restore and Protect to clean that well around the rings in a typical car may be unrealistic.
The IIIH test is described here (this may not be the "adapted" form used by Valvoline):
https://www.swri.org/sites/default/files/sequence-iiih-test.pdf
Most cars at 3900 RPM would be moving at 80 mph (or more) on a flat straight road, and in this test, that "speed" is maintained for 90 hours (almost) continuously. This is essentially an Italian tune up on mega steroids - equivalent to sustained continuous 80 mph for 7200 miles. Vanishingly few cars are driven anything like that. Consider the motor's duty cycle. It is hard to imagine many cars go more than 4 hours or so before the motor is turned off for at least 10 or 15 minutes (gas and/or bathroom stop). In the test that duty interval is 20 hours, and then off only briefly (for lubricant level checks). Most cars are turned off and at ambient temperature at least 12 hours a day, with many, perhaps most, being off for 22 or 23 hours a day. Our Prius is probably about as far from the IIIH test as possible, since even when the car is moving the ICE motor shuts off periodically, sometimes even in highway driving, and it only rarely ever sees RPM that high, like when climbing a steep hill or passing.
I think Valvoline should employ a test which at least bears a plausible relationship to what most cars see. Starting with a motor which has significant deposits on the pistons and especially in the ring grooves and on the rings, something like: 240 hours total in cycles of 1 hour at 2000 RPM, 1 hour at 2500 RPM, then 2 hours off. Based on the (lack of) reported cases of Valvoline Restore and Protect curing oil burning, I predict that cleaning around the rings would not be nearly as complete as in the IIIH test. I propose that this be designated the "Put up or Shut up" test for cleaning piston deposits, PUOSU for short.
Thoughts?
Thoughts?
