No. It's a novel "something" from what they've said. This doesn't use the traditional polarity method. Whatever it is it seems to dissolve carbon.
Seems to have sorted the consumption out. 3k miles. Changed to it earlier this year.I'll be doing the same on my son's older Focus next year for it's annual change. HPL user here.
The story is Valvoline has a research lab overseas; if I recall, where the lab folks synthesized a new molecule.So is it some kind of solvent but stable and won't evaporate or degrade over 10k miles/1y of usage?
It reminds me of glyphosate unique molecule that is hard to find the homology, unlike agent orange.
Agent Orange contains two active ingredients, 2,4-Dichlorophenoxyacetic acid (2,4-D) and 2,4,5-Trichlorophenoxyacetic acid (2,4,5-T), which other companies can easily modified and still have similar effectiveness.
I'm trying it now. Consumption on this Fit has been a consistent 1 Quart / 4k miles since 200k on the engine. It just passed 350k right after the swap to Valvoline Restore and Protect. Might take up to a year for results.Seems to have sorted the consumption out. 3k miles. Changed to it earlier this year.
Valvoline has stated in interviews that Valvoline Restore and Protect’s cleaning comes from an additive. The additive was discovered in a lab in Mumbai India.
Valvoline stated that the additive was discovered in a lab in Mumbai? Or is that your addition.
It's on this video at the 2:30 min that they mention Mumbai, India. The video was shot at Lexington, KY.
Alkyd-Naphathene? I know I'm wrong and I'm okay with that. Could it be possible that it has a higher volatility rate so that whatever it comes in contact with that's varnish it's more likely to burn off so that it's more than likely to cause some topping off. Though then again some people have used it and not required any oil at all between interval changesWell, it does, but the chemistry doesn't show in a cheap VOA!
1 quart every 4,000 miles is considered normal, I wouldn't expect much of an improvement in regards to consumption.I'm trying it now. Consumption on this Fit has been a consistent 1 Quart / 4k miles since 200k on the engine. It just passed 350k right after the swap to Valvoline Restore and Protect. Might take up to a year for results.![]()
I’m not exporting much either, but I figured it couldn’t hurt. It’s possible there is something to clean up from my numerous extended OCIs for years (when I did not use the best oils for that).1 quart every 4,000 miles is considered normal, I wouldn't expect much of an improvement in regards to consumption.
I don't think it burns-off anything but solves it. Alkylated Naphthalene has some minor solvency but not the kind to break up carbonaceous material.Alkyd-Naphathene? I know I'm wrong and I'm okay with that. Could it be possible that it has a higher volatility rate so that whatever it comes in contact with that's varnish it's more likely to burn off so that it's more than likely to cause some topping off. Though then again some people have used it and not required any oil at all between interval changes
Chemical companies work with universites all over the world to help develop special chemsitries. Nothing really new about this.I watched it again. Developed here (theoretical molecule ex), synthesized in Mumbai, then sent back to KY and tested/validated.
What is a nano technology particle? You mean like a micro abrasive?I think Valvoline is using some nano technology with adhesive molecules, but I'm just guessing. People started talking about nano technologies like 15 years ago. So, for sure we have some already developed technologies, but they are kept a secret. Nano technologies are not a joke because there are particules that work but you cannot see them with naked eye, so it's easy to freak out people.
Maybe there is already toothpaste with nano particles that will clean around and between your teeth even better.
Does the gap between your teeth is smaller or larger than the one b/w main bearing journals or b/w the oil piston rings gap?
Yes 1 quart every 4,000 miles is in fact considered normal by Honda and it is considered normal by other manufacturers as well, in fact other manufacturers have even worse oil consumption rates that is considered normal.Nope, 1qt for 4,000 or 5,000 miles is not normal. My car burns that much oil and next year I'll try Valvoline Restore and Protect to lower it down.
In the video above the Valvoline R&D men say that Valvoline Restore and Protect is designed to clean slowly your engine, not rapidly as the previous Valvoline Blue Restore, so it doesn't plug in filters and catalytic converters.
So that's why it's recommended to do at least 4 OCI because the oil is designed to clean slowly, step by step.
This is correct. Some manufacturers allow up to one quart per 1k miles.Yes 1 quart every 4,000 miles is in fact considered normal by Honda and it is considered normal by other manufacturers as well, in fact other manufacturers have even worse oil consumption rates that is considered normal.
Honda actually has a threshold of 1 quart every 2,000 miles before they begin to consider it excessive oil consumption.
