4wd
$50 site donor 2026
My Super Tech HD30 OPE oil sez bring that KRL inside this humpty bumpty
On the flip side - looks like a healthy amount of ester for something not driven oftenAgree and to be truly effective, the tests also should have been run several times for each oil in other orders. That said, this was better than most and the TEOST test does have me slightly rethinking Redline, my go-to oil, in a new to us vintage non water-cooled turbo...
I have the same thoughts. I would have liked to have seen him test Mobil 1 Extended Performance instead of Truck & SUV, because EP is the direct competitor of Pennzoil Ultra Platinum, while Truck & SUV is fairly niche.I liked this set of tests. One thing that stood out was how brutal the KRL test really is, all of these oils showed minimal shearing after two hours on the dyno. That taps into a question I’ve had for a while, how much real world use (daily driving or even HPDE track hours) would it take to mimic the KRL results?
One thing I will criticize is the choice of oils, the only other “off the shelf” oil that Pennzoil Ultra Platinum was put up against was Mobil 1 Truck and SUV which is certainly a choice. I know in a previous video that oil was shown to be pretty stout with AN in the base oil blend but why not go with Mobil 1 ESP which he’s also shown to be shockingly shear stable, along with being cheap and easier to find than Pennzoil Ultra Platinum.
If you really want to declare Pennzoil Ultra Platinum as the king of off the shelf oils you at least need Castrol and Valvoline in the mix. Mobil 1 wasn’t far off from Pennzoil Ultra Platinum, I’d wager within experimental error. Question for the crowd, what did Pennzoil Ultra Platinum do that was widely better than Mobil 1 Truck and SUV which again isn’t even their top tier oil unlike Pennzoil Ultra Platinum.
If you’re focusing on the TEOST deposit results the euro formulations of Mobil 1 (which ESP would cover), Castrol, and Valvoline should be in the mix. Those are also all cheap and easy to find.
You’re not wrong![]()
And, it confirms what some have surmised between the two oils since that video: Run shorter intervals if using Pennzoil Ultra Platinum and if using AMSOIL Signature Series it has more headroom for extended drains.Isn't that ironic? LOL
Well, to be fair, in a basic $30 analysis, can we even attribute metals to current oil in use?Waiting to see how many argue for HPL's wear metal numbers.... and discredit Molygen lol
Lake actually mentioned in the vid all wear metals were essentially the same. Which is what we have been saying here for years. A couple ppm of wear metals on a used oil analysis is just noise.Waiting to see how many argue for HPL's wear metal numbers.... and discredit Molygen lol
Why do we conclude it doesn’t make real world difference? Just because we aren’t seeing evidence ourselves doesn’t mean it doesn’t exist.Interesting testing, not sure it'll change anything that I'm doing, though. In the end, I wonder how much real world difference any of this makes for most of our cars. I'd wager not much, of course, that isn't why we are here, I guess. I was disappointed with RL's showing, though.
It's amazing how common sense usage doesn't count for anything to some. Oil A produces less wear than oil B but wait! Lets argue against if it was a certified lab or not.So… Project Farm had it right all these years?
(proceeds to run after posting rage bait)
I just did my entire 2008 GMC Duramax pickup in Amsoil because I just bought it with 178k miles and didn't know the previous maintenance. Peace of mind and it honestly isn't that much more. Their gear oil is absolute top notch. To me, my use case, the absolute clear winner here is Molygen. Results speak for themselves and I use FCPEuro for it. I do 5k change intervals in my Grenadier, or before and after a big road trip like Texas to Moab and back where I'm really hammering it out there. The shorter OCI makes it a confident choice. I see the sheer numbers, doesn't really mean much here.Bottom line: There is no "Best Motor Oil".
It's application specific, depending on the car/engine and it's unique needs and demands, which depends in part on how you drive and your typical OCI. Having said that, the real winner, and one that stood out here was Pennzoil Ultra Platinum. I still feel good about running Amsoil as well.
Motul 300V seems to do great in low 5k OCI.We absolutely know race oils make terrible street oils.
I saw this in 2006! I ran racing 5W-20 in our Honda Ody. Filthy!
How are you determining “less wear” - because if it’s Project Farm methodology - I am not sure you achieved valid results. The one arm bandit test is meaningless, and yet, he employs that kind of testing.It's amazing how common sense usage doesn't count for anything to some. Oil A produces less wear than oil B but wait! Let’s argue against if it was a certified lab or not.
Who do you believe their tests are more accurate, Blackstone or Polaris Labs? Or are they the same in your eyes?It's amazing how common sense usage doesn't count for anything to some. Oil A produces less wear than oil B but wait! Lets argue against if it was a certified lab or not.
And yet it had the lowest engine dyno wear metal rate, along with a low temperature during those dyno runs, a high peak engine torque, and a really low turbo deposit rating.I don't think this video makes Molygen look good at all.
Almost 15% shear at 100C, almost twice the shear of the second worst one.
