LSJR Boutique vs OTS shootout
Bottom line: There is no "Best Motor Oil".
It's application specific, depending on the car/engine and it's unique needs and demands, which depends in part on how you drive and your typical OCI. Having said that, the real winner, and one that stood out here was Pennzoil Ultra Platinum. I still feel good about running Amsoil as well.
HPL, Driven and RL would not meet the 30mg threshold for TEOST. The RL TEOST results are similar to what Amsoil found. Actually RL results are off the charts bad. Would you run that oil in a turbo? I don't know. I know the TEOST isn't everything, but it is a test.
"The maximum mg limit for a TEOST test (Thermo-Oxidation Engine Oil Simulation Test) varies by specification, but common limits are around 30-35 mg for modern API/ILSAC oils (like GF-5), while older specs might allow up to 60 mg, and newer ones push for even lower deposits (like 25 mg) to protect turbos"
No, no more Redline engine oil, not after seeing this. I was done with them after the price gouging anyway.
No, no more Redlin, not after seeing this.
Amsoil tested RL back in 2014 and it didn't meet the min. Now whether it actually matters in the real world I don't know. It's still considered a legitimate test and Amsoil seems to value it. I have posted on some of the questionable aspects of it as has Gokhan. That's really all I can say about it.
From what I gathered in the Gale Banks Amsoil videos is that deposit chemistry is challenging and requires careful balance. So there's that too....
RL's results were extremely bad though at nearly 128mg. So I'd pass as well....
I'd be curious what RL thinks about that.
I liked this set of tests. One thing that stood out was how brutal the KRL test really is, all of these oils showed minimal shearing after two hours on the dyno. That taps into a question I’ve had for a while, how much real world use (daily driving or even HPDE track hours) would it take to mimic the KRL results?
One thing I will criticize is the choice of oils, the only other “off the shelf” oil that Pennzoil Ultra Platinum was put up against was Mobil 1 Truck and SUV which is certainly a choice. I know in a previous video that oil was shown to be pretty stout with AN in the base oil blend but why not go with Mobil 1 ESP which he’s also shown to be shockingly shear stable, along with being cheap and easier to find than Pennzoil Ultra Platinum.
If you really want to declare Pennzoil Ultra Platinum as the king of off the shelf oils you at least need Castrol and Valvoline in the mix. Mobil 1 wasn’t far off from Pennzoil Ultra Platinum, I’d wager within experimental error. Question for the crowd, what did Pennzoil Ultra Platinum do that was widely better than Mobil 1 Truck and SUV which again isn’t even their top tier oil unlike Pennzoil Ultra Platinum.
If you’re focusing on the TEOST deposit results the euro formulations of Mobil 1 (which ESP would cover), Castrol, and Valvoline should be in the mix. Those are also all cheap and easy to find.
If I had to pick an absolute overall winner - Pennzoil Ultra Platinum and AMSOIL Signature Series.
Depends on the application, though, doesn’t it?
For a regular driver in a regular street car, changing the oil on time, yeah, those are two great picks.
I thought the results were interesting, particularly this comment: “Modern oils will protect your flat tappet cam”.
So very many posts on BITOG about “needing Zinc” in a certain PPM for flat tappet cams.
Evidently, not true.
Interesting testing, not sure it'll change anything that I'm doing, though. In the end, I wonder how much real world difference any of this makes for most of our cars. I'd wager not much, of course, that isn't why we are here, I guess. I was disappointed with RL's showing, though.
I wouldn’t be disappointed with Red Line’s showing - it’s not made for a street car with the oil changed at regular intervals, is it?
Just because something is a “racing” product, doesn’t mean that it is better for everyday use.
Definitely need to see how this looks with Valovoline Restore and Protect, Mobil 1 Extended Performance/ESP, and Castrol Edge included. Throw in Supertech for good measure.
Allow me to add, that in a recent thread on boutique oils, I explained why I chose the Pennzoil Ultra Platinum, and the AMSOIL Signature Series, for two different, street driven cars that had the oil changed at regular intervals.
The results of this set of tests is comforting in that it supports those oil choices, made many years ago.
