Oh, Terry, there are surely a multitude of preferred methods and chemicals that may be favored over MMO and how I used it. This in no way says that MMO is the best product ..nor that I used it in a favorable manner. Certainly my method would not be recommended in any application of any additive.
I don't have your reservations for the introduction of ATF since my experience doesn't give me cause to. Your experience and knowledge obviously cause you to conclude otherwise. Perhaps we can agree to disagree on this point.
This only states, or shows, what didn't happen in my use of this product in this manner. FP may have produced like results used in a like manner ...or like results used in its prescribed manner. I don't know that since I didn't use it
I don't have easy access to a borescope. This would have been the only other way to show these results of my use of this product. Otherwise I would be limited to our usual indicators .. MPG, "easy starting", and the good old butt dyno
As alway (and I'll reassert this) this is offered FWIW
Edit: I don't use MMO as something like LC. They're different animals. I usually limit MMO to my oil fired boiler. This was about the first time I had used it in an engine in many years. I merely wanted to have convincing evidence that it did no harm.
MMO's formula has changed since its creation. There were differnces in MSDS sheets that breached certain years. There was probably a combonation of reasons ...everything from more contemporary plastic packaging ..to removing some agent that was harmful to cats.
MMO
Stoddard solvent 008052-41-3 (less then)30
Distillates, petroleum, solvent-refined heavy naphthenic 064741-96-4 (less then)75
Distillates, petroleum, solvent-dewaxed heavy naphthenic 064742-63-8 (less then)75
MMO with 6/20/02 date (I dunno if the other is before or after
Chemical CAS No / Unique ID Percent
o-Dichlorobenzene 000095-50-1 0-1
Stoddard solvent 008052-41-3 20-30
Hydrotreated heavy naphthenic distillate solvent extract 064742-52-5 70-80
Source:
Household products MSDS Hit Auto, Motor Oil, additive to find these MSDS sheets.
[ June 09, 2005, 10:14 PM: Message edited by: Gary Allan ]
