My personal anecdotal experience, it works pretty well. I use it every few oil changes.
Not sure if this has been posted but:
https://www.liqui-moly.com/fileadmi...a_Tec_Additive_EN_1802_view_M014152_53095.pdf
Formed in 1989, APL is a neutral and independent, internationally re- nowned development service provider, working for a worldwide client base from the automobile, oil and additives industries. The company is specialized in the mechanics of engine and drive trains and their oper- ating supplies. On nearly 145 state of the art engine and component test rigs, more than 700 employees apply the latest measurement technology.
Proven efficiency
Test arrangement with two inter- locking gear wheels.
LIQUI MOLY products stand for reliability, efficiency and for top quality – a per- formance promise which an independent institute, renowned in the best sense of the word, should put to the test: The Automobil-Prüftechnik-Landau GmbH (APL) tested Cera Tec.
What was tested
The APL experts determined the relative scuffing load capacity of lubrication oils. Between the edges of the teeth, rolling off and sliding occur at the same time. Due to unfavorable operating conditions the lubricant film can break down be- tween the tooth edges. This leads to short-term local fusion and disintegration of the edges, so-called scuffing, which causes damage to the smooth surface of the teeth edges. Possible consequences: higher engine and transmission noise until failure of the gear wheels occurs.
Test sequence
On the vehicle distortion test bench the test oil was mixed with 6 per cent Cera Tec. With each test sequence the weight, and thereby the force level, on the sensitive transmission gear wheels was increased. The aim of the experiment
is to reach the damage force level. This level is reached when the sum of all damage caused to the teeth of the gear wheels is more than 20 millimeters.
The test is then ended. The reference oil came up to damage force level 4; the oil mixed with Cera Tec reached as far as level 9, hence to more than double the level. «Cera Tec markedly increases the power reserve, which confirms the an- ti-wear protection by the fine ceramic particles,» is how Dipl.-Ing. Peter Kunz, who supervised the test, summarizes the results. Kunz’s initial skepticism gave way: After the tests I was amazed. The product has made everything, and I really mean everything, better.»
Just the demand for APL’s expertise alone has been unusual. «LIQUI MOLY is the first company in the after-sales market that has been prepared to undergo volun- tary tests», said Kunz. He is responsible for the testing of lubricants and fuels.
In short: Cera Tec reduces the amount of friction and thereby the wear. This in turn benefits the engine, which is under less load. This can result in a lower susceptibility to repair and longer service life.
