I know the IS250 is bad, and that the dashes from around 2007-2008 tend to decompose in the sun. Any other years/models to avoid?
LS460Unless you work on them yourself.
Hybrids are automatically out of consideration for me.As far as I know, the 250 models had issues with the 2.5 V6 only having direct injection without port injection as well. The little hybrids had head gasket and engine issues too.
That is absolutely not the case.I would just buy a Toyota and forget about the Lexus brand. Kind of like Honda vs Acura. All you end up doing is paying extra for maintenance and parts. If you bought a brand new one it would be a different story. Honda's and Acura's are great however whomever buys them after the warranty or 150,000 miles gets to pay the high replacement part game.
What do you want? IS, GS? I mean, everything depends. Avoid IS250 like a plague. It is probably the worst CBU offender on the market. Their 2.0T engines are just average.Hybrids are automatically out of consideration for me.
Yeah the 2006 LS has the battery rearward on the passenger firewall side. I’m very careful to replace the plastic sleeve. Didn’t do that on the Maxima and gassing corroded the fender. Even my wife’s GM SUV put the battery under the rear passenger’s feet. Japanese should go the extra step. They don’t always think all the way through, such as having a rain sensor for the wipers and eliminating intermittent. Germans have both.That is absolutely not the case.
Lexus has a bigger separation from Toyota. ES models? Yes, glorified Camry. My in-laws have a 2011 ES350, and it suits them.
However, IS, GS and LS are proper vehicles. Properly positioned engine, different suspensions, simply they are built to compete with MB, Audi and BMW. They don't have attention to details as German vehicles (for example IS has battery under the hood, which is absolute NO for vehicle that strives to compete with 3 series) but they ain't just glorified Camry.
They don't. Numerous missed opportunities to have an absolute winner, including the current IS500.Yeah the 2006 LS has the battery rearward on the passenger firewall side. I’m very careful to replace the plastic sleeve. Didn’t do that on the Maxima and gassing corroded the fender. Even my wife’s GM SUV put the battery under the rear passenger’s feet. Japanese should go the extra step. They don’t always think all the way through, such as having a rain sensor for the wipers and eliminating intermittent. Germans have both.
Maybe it’s just me but I do consider Lexus to be the top marque for Japan. My recommendation is to drive the one you are interested in. There are models which don’t have any steering feel whatsoever. I get it many like that today so that’s fine…
Not quite sure what happened to my fontThey don't. Numerous missed opportunities to have an absolute winner, including the current IS500.
It has some DI deposit issue that Lexus issued TSB for owners to bring back for ring and piston replacements. Most of them are replaced now and that basically postponed the problem from reoccurring again. The rest of the car is fine other than being tiny on the inside. It is a quality little car, and if you like it you can still just bring it to someone to do walnut shell blasting on the intake valves once every 60-80k or so.As far as I know, the 250 models had issues with the 2.5 V6 only having direct injection without port injection as well. The little hybrids had head gasket and engine issues too.
I liked the one that Hoovie picked up years ago on YouTube with a 5 speed, a ‘93 ES300.It has some DI deposit issue that Lexus issued TSB for owners to bring back for ring and piston replacements. Most of them are replaced now and that basically postponed the problem from reoccurring again. The rest of the car is fine other than being tiny on the inside. It is a quality little car, and if you like it you can still just bring it to someone to do walnut shell blasting on the intake valves once every 60-80k or so.
The front tires get inner shoulder wears very fast, like every 30k if you use the long lasting tires. It is likely due to the caster from the factory and nothing can improve it. Again, depends on how much you drive it it may not be a big deal. Those tires are like $110 ea and not too expensive.
Overall a nice little car for someone who doesn't need the space. It has depreciated a lot by now and is a good deal if you fit the usage. I would buy it again.
